I can't get my Directv remote to work on my new Sylvania TV. Customer service is no help at either company.I can't get my Directv remote to work on my new Sylvania TV. Customer service is no help at either company.
Sorry to say I also have the same problem programming my Sylvania 19" to DirecTV. I tried doing it manually, but half way through the search the DirecTV menu disappears and sets back to viewing regular TV. The directions state that the process could take up to 30 minutes to complete, but it cuts out after about 10 minutes into the search. Pretty frustrating and time consuming .Sorry to say I also have the same problem programming my Sylvania 19" to DirecTV. I tried doing it manually, but half way through the search the DirecTV menu disappears and sets back to viewing regular TV. The directions state that the process could take up to 30 minutes to complete, but it cuts out after about 10 minutes into the search. Pretty frustrating and time consuming .
You can't post conmments that contain an email address.
DIRECTVTo do this, press and hold the MUTE and ENTER buttons while pointing at your Genie HD DVR, Genie Mini, or Wireless Genie Mini. The screen will display Applying IR/RFsetup. To program your remote to control a regular HDTV (not a DIRECTV Ready TV) or audio devices, follow these steps: Press MENU on your remote.
DIRECTVHow do I connect my DIRECTV receiver to my TV? Print. Email ... This will help you determine what cable to use to connect your receiver directly to your TV. ... For example, a DIRECTV receiver, DVD player, Blu-rayâ„¢ Disc player, o... How to ...
POWER (pl 1)
Press to turn the unit on and off.
INPUT SELECT (pl 3)
5. SETUP (p11)
Press to display the main menu.
6. infrared sensor window
Receives infrared rays transmitted from the remote
control.
7. power on indicator
Lights up when power is on.
8. standby indicator
Lights up in standby mode.
These codes control Sylvania TV with the RC65, & I suspect they work with the RC64: 11864, 10171, 11271, 11314, and 11394.
Instructions for entering the codes are here. Instructions for searching for the proper code instead of trolling through that list are here. If you'd like a digital manual for your RC65, click here.
Programming DIRECTV Remote
1. Locate the DIRECTV Receiver's brand and model number
(on the back or bottom panel) and write it in the
spaces below.
2. Locate the 5-digit code for your DIRECTV Receiver (see
page 10).
3. Power on the DIRECTV Receiver.
4. Move the slide switch to DIRECTV icon.
5. Press and hold in the MUTE and SELECT keys until the
green light under the DIRECTV icon flashes twice and
then release both keys.
6. Using the number keys enter the 5-digit code. If performed
correctly the green light under the DIRECTV icon
will flash twice.
Magnavox codes:
11454, 10054, 10030, 10706, 10179, 11254
7. Aim the remote at your DIRECTV Receiver and press
that the power key once. The DIRECTV Receiver should
turn off. If it does not turn off, repeat steps 3 and 4, trying
each code for your brand until you find the correct
code.
8. For future reference write down the working code for
your DIRECTV Receiver in the blocks below:
Once you have programmed the DIRECTV remote control for
your TV, you may want to activate the TV Input button.
1. Move the slide switch to the position under TV icon.
2. Press and hold the MUTE and SELECT keys until the green
light under the TV icon flashes twice and then release
both keys.
3. Using the number keys enter in 9-6-0 (The green light
under the TV icon will flash twice)
You now have the ability to control the Input select feature for
your TV.
look in the comcast remote guide and find your tv code. there should be directions in the guide that tell you how to program it. if not call your local comcast provider and they should be able to walk you thru it.
To program a TV you can use the code search option. You do this by making sure the TV is turned on then point the remote at the TV then press the TV button once, then press and hold down the set button until you see the RED l.e.d light blink twice, then enter the code 991. Next press the power button then the TV button continue doing that until the TV turn off, when it does press the set button. Press the power button and the TV should turn on again.
having the same problem as jw, anyone help?
yep me too
Have the same problem with my Sylvania, also with two Westinghouse TV's
universal atlas ocap 5 have entered all codes sugested by them none work
No code works on DirecTV remote for Sylvania LCD TV.
I can' get any of my remotes to work with this television.
Whats the cure? I bought a big button Universal Remote and no codes work either
I want to program my Comcast remote to control my new Sylvania LC195SL8 TV receiver. I can not find the remote code that I need.
