SOURCE: my standby light flashes red/blue? and no pic,its only weeks old
I would take it back and get a replacement, it is a lemon, it will void warranty if you open it up. It can be defctive power supply module.
SOURCE: sound but no picture on
The LCD backlight is faulty. it may be due to bad capacitors or a faulty inverter controller. Bad capacitors can be easily replaced. A faulty inverter controller is a bit more tricky but it can also be replaced.
SOURCE: My goodmans tv switched itself off and won't work
It is a power problem, check if there is current on the power transformer, that is the wire that connect from the transformer to the panel.
