Hello, this is error for waste toner, and the waste toner needs to be cleaned.
On left sideway of copier, in lower left corner you will see the plastic cover with one screw.
Remove the plastic cover and remove waste toner box by pulling toward you. Empty it and clean the neck of the bottle. Put it back in and restart copier,
e-000013, it is all about waste toner. possibility : - waste toner case was detecred full. - The PLL lock is
released because waste toner motor is locked up, etc. - The micro switch employed to detect clogging of waste toner is
activated. the position behind-below of copier. open the beck cover and you ll see it.
Hello, on back side of the copier are small black switch, it is protective fuse. Try to put him back ON. If these doesn't helps you have power supply problem....
Let the front of the canon copier/image runner iR 3300 as a referrence, waste toner bottle is located under neath the small cover of size 15 cmsX 30 cms and this small cover is located at the extremely lower left corner of the copier/image runner iR3300.This small cover will fixed with one and only one screw at the upper/top right corner of the small cover. Un screw this small cover and remove the small cover along with the attached screw and kept aside. Under neath this small cover there will be a big plastic bottle which is called as the waste toner collection bottle. The capacity of this bottle may be 11/2 kgs to 2 kgs. When this waste toner bottle was filled up , a message will be appeared on the screen that ' replace the waste toner collection bottle'. Even after the this message the copier/image runner may work properly. If the message of error code E000019-0000 appeared on the screen this waste toner bottle may be filled completly. Then the coper will stops to work. Then gently remove this waste toner collection bottle slowly and empty the waste toner bottle which was filled up with waste toner within the plastic bag. Wash this waste toner bottle with soft water 2 or 3 times and there after with soft detergent washing powder , so that no stains of waste toner or any type of stains may be completly removed. Please don't try to remove the water particles with cloth or any thing Or don't try to remove the water particles with Hot hair dryer. After washing the waste toner bottle , dry this with the air coming from cealing fan or with cold hair dryer. After the waste toner bottle was completly dried withj the cold air replace the this bottle in the original place. Before replacing the waste toner bottle in its original position clean the place of waste toner base / holder -up , down, left & right with the clean and soft cloth which is under neath the small cover. Hurray ! your problem will be solved completly without any expenditure but you may expected to take time with patience.
E000019 means the waste toner is full. It needs to be emptied out. It is behind the front cover of the copier. There are two screws that hold it in place. Open the toner door and there is one screw there set into the plastic. The other one is on the top left coner of the cover, that may be out? Slide the cover to the left and the waste toner bottle is right there, milky white bottle. Pour it out carefully. Reinstall and turn the main power switch off then on and you are done
Turn off the copier. Remove the lower left panel on the left side of the copier, then pull out the plastic container and empty it. Reinstall the container and cover then turn the machine back on.
Then on the flat surface under the paper delivery tray there is a round cutout , remove this little cover to reveal a screw, undo this and slide the front cover off to the left. The waste toner bottle is now visible.
