Linksys WRT54GX2 Wireless-G Broadband Router with SRX200 (LS-WRT54G2) Logo
Posted on Sep 29, 2009
While trying to connect a pc to the WRT54G2 wireless broadband router,windows gives me the following message: ''windows cannot find the certificate to log on to the linksys network'.what is the problem with configuration or what should i do to solve the problem.
Anonymous
Level 1:
Problem Solver:
  • Contributor 16 Answers
  • Posted on Sep 29, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
16
Questions
Helped
5534
Points
30
On Windows XP
>>right click wireless connection icon >>view available wireless network >>click on change advance settings inte left(SP2) orAdvance(SP1) >>on top click on tab wireless network >>clear preffered networks >>Click on ADD below preffered network box >>Put in the details for the titles mentioned below Association(Tab) >Network Name (SSID) : put in your wireless network name >Data Encryption should be check >Network Authentication(Shared mode) should be unchecked >The key is provideded for me automatically uncheck it >put the network key and confirm it Authentication(Tab) >check Enable IEEE 802.1x >now uncheck Authenticate as Computer when computer info is available >now uncheck Authenticate as as guest when user or Computer when computer info is unavailable >uncheck Enable IEEE 802.1x >>click OK now it will start working enjoy
Slow internet speed when connected to router
So, If you have internet connection speed problem with your wireless try with the following steps,
1.)Reset the wireless router by using the power switch on it or by unplugging it and plugging it back in.
2.)Place the wireless router in an ideal location. The higher it is, the better, but don't put it near metal objects.
3.)Get as close as possible to the router with whatever device you're trying to connect.
4.)Keep the router and your connecting device away from other electronics. You should especially keep away from phones, fax machines and microwaves. etc.,
5.)Adjust the Wifi antenna if it has one.
6.)Change the router's channel, especially if other wireless routers are nearby.Following these steps would give you stable internet connection and also increased speed in connection. You can check your internet speed from www.ScanMySpeed.Com before and after following these steps.
Hi i want network key of linkeys wrt54g2 router
Please login to router page by 192.168.1.1 enter user name = blank and password = admin
Once you click on the wireless tab>wireless security
Under this you can check the wireless key.
please follow the link.
Wireless Security
Show me how to connect linksys wireless
Hi
The Router configuration is not that much difficult, only few thing you have sure,
1) Correct ADSL Connection User name & password,
2) Chose unique ip address in All host.
Follow the mention bellow instruction to configure and connect to Wifi Router,
  • Plug the network cable ( Mine was Blue ) which comes with the Router Box pack to your computer. The other end goes into any of the Router Ethernet Port ( 1 or 2 or 3 or 4 )
  • Now type in 192.168.1.1 in IE or Firefox or any browser. You will prompted for password which is admin. You must be logged into Linksys Router.
  • Now since your ADSL modem is also having the same IP , we will change the IP address for WRT54G2 Router to 192.168.5.1
  • Under Setup >Basic Setup look for Network Setup and Change Router IP. Change to 192.168.5.1 and Save changes.
  • Since the IP has changed you will need to close the Browser.
  • Sometimes the IP doesnt change automatically. Do a IPCONFIG / RELEASE and then IPCONFIG / Renew
Making WRT54G2 Router talk to ADSL broadband modem
  • Plugin the Ethernet cable which comes from the Modem into the port on Wrt54g2 router which says Internet.
  • Open Internet Explorer and Type in 192.168.5.1.
  • Type in same password ( admin )
  • You will be in Setup > Basic Setup
  • Take a look at Section , Internet Setup. The current selection should be Automatic Configuration DHCP. Select Static IP instead.
  • Add following details to it. In the first step we backed up All the IP configuration. Use them here
Internet IP Address: . . .
Subnet Mask: . . .
Gateway: . . .
Static DNS 1: . . .
Static DNS 2: . . .
Static DNS 3:
ADSL Modem Settings to Wrt54g2 Router
  • Once Done just save changes and you should be back at same page.
  • Now try to connect any application which talks to internet. You should be able to connect
Configuring for Wireless Connection :Now once your Router is talking with Modem, it is pretty easy to connect on Wireless. The only thing we need to setup here is Security. Lets get WIFI
  • Get to the Lynksys page again. Do all login and regualr stuff.
  • Now look for menu Wireless, click on it. You should land on Basic Wireless Settings.
  • Select wireless configuration to Manual .
  • Wireless network mode to Mixed.
  • Give a Wireless Network Name (SSID), make sure its unique.
  • Make Wireless channel selection 11 ( 11 - 2.463 GHZ)
  • Select Wireless SSID Broadcast to Enable
  • Save Settings and you will be back at the same page with changes you made.
Now Lets secure the Router :
  • Go to Wireless Security on the same page.
  • You will need to configure here Security Mode : WPA Personal, WPA Algorithms: TKIP
  • WPA Shared Key is what you will need when you connect to your router without wire. This key does the authentication and keep unwanted people away. Add 8 digit alphanumeric key.
  • As suggested in comments, there is a new mode which you can use : WPA2 with AES
  • Save changes.Just make sure you save that key to a notepad or remember it.
Wrt54g2 wireless security
  • Now last step, Move to next menu Security > Firewall .
  • Uncheck Block Anonymous Internet Requests .
  • Save Settings.
Wrt54g2 firewall settings
  • Remove the blue cable which you had connected with Router.
That's it. Now just turn on your WIFI and Search for the router. The name should be visible. Click to connect. At this stage it will ask you for the Password or Shared Key which we configures just above. It will connect and you will be able to connect to Internet.
That's all Folks. This is how you connect WRT54G2 Linksys router with Adsl Broadband Modem. If you have any questions feel free to comment.
Wireless connection problem
hi
go to following link it will give you all your solution for wireless networking
http://www.microsoft.com/windowsxp/using/networking/setup/wireless.mspx
Hi, im geraldine and i forgot my password in linksys router
Hi Geraldine
If you have forgotten your wireless password follow these steps from a wired computer
1>Start->Run->CMD->Ipconfig
2>You'll find default gateway
3>Type only the numbers on your browser window or type in eg:: http://192.168.1.1 in the run window
4>You"ll see a router setup page opening up
5>On the left hand side under wireless you"ll see security
6> Click on that you"ll see a 10 digit or 26 digit no if it wep security or a password if it is wpa .
7> that would be your security key for wireless
Linksys wireless adapter and linksys wrt54g2 router not seeing each other
its possible that the wireless card does not have the correct wireless settings.
Open the linksys wireless monitor on your wife's laptop.
Go to the profiles tab, highlight the default SSID then click on edit at the bottom. It will search for the wireless network, from the list of networks that it will show you, click the name of your wireless network, in if the network is secured you will be ask to put in your network key. Then click connect. Then it will say that you profile was successfully configured. then click connect to network. It will take you back back to the screen where you saw no association to the access point, check if you will now get a new message. On that same screen click the more info button at the upper left hand side. Check the IP address it should be 192.168.1.x. If you have that IP then you can test if you will be albe to get online.
if you still have any problem just reply to this post.
Connecting a Ipaq RX3715 to a wireless router
First, you have to be sure your ipaq has wi-fi feature is on and you can check on network connectivity option for any wrong setup there. According to your information, your ipaq is not recognized by your router and I agreed that your router is working normally. Try to reboot your ipaq and be sure to get wi-fi to turn on and try to connect it again. I have my Dell Axim also used Windows Mobile like Ipaq and it connected easily with no issue. The message in your to show me that you need first to identify your ipaq before you you can get it to connect to your network. I hope this help.
Top Linksys Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
