Some mouses stop responding if you do not use it for a few minutes. This is usually a battery saving feature. Usually all you got to do is use the scroll button to reactivate the mouse by scrolling up or down. This will bring the mouse back to life. When you change the ports you are actually doing the same thing (reactivating). Also check whether battery needs changing.
Hello, if your touch pad is diabled you need to enble it from VAIO Control Center. You need connect a external mouse in order to follow the steps easily: Click Start, All Programs, and VAIO Control Center. From there you need look for Touch Pad > enable it.
Check the mouse with any other laptop/desktop, if the scroll is working there. If its working then try a different USB port to connect the mouse and install any softwares which came with the mouse.
If its not working with other PCs also, then you need to get a new mouse or claim the warranty if your mouse is in warranty.
connect your mouse. then restart your laptop do not remove mouse while restarting laptop. if not work after restart there is a problem in your mouse IC.
i have two solutions for you. the touch pad can be disabled on the motherboard so plz hold-down the fn key and press the function key that has the sign of a hand pointing something and the second is that ur drivers that enables thae touch pad to work has been courrupted so plz try reinstalling for the touchpad or try repairing ur operating system.
My Vaio touchpad started behaving strange. I could move the curser, but no response on left or right click or double tap. Also found that in any search field or user name fields, the computer would just type endless 9's. My wireless mouse could operate the left and right click buttons, but not move the curser. A suggestion to get the mousepad operating again was to touch any key on the keyboard. This allowed it to function again. Final solution was to remove the battery, then hold down the start key for about a minute, reinsert the battery and start it up. It seems to have resolved the problem. I have a 3 month only laptop with Windows 7 already installed. Hope this helps.
