Im using Panasonic KX-FT 77 and it does not start a fax, a CALL SERVICE 2 is displayed.. Pls help me fix this problemIm using Panasonic KX-FT 77 and it does not start a fax, a CALL SERVICE 2 is displayed.. Pls help me fix this problem
Thanks to all for solving the "service call 3" with my Panasonic KX-FLB811
I had this nagging problem the whole afternoon,
Why is Panasomic making it so difficult for its customers??
1. enter The #9000* ( without forgetting the star * at the end like I did the first time)
2 enter the 550
3. press the start button, and
4 turn off for 10 seconds
5 turn on the power
It works....
You made my DAY!
Pentar
2 enter the 550
5 turn on the power
Add a CommentIm using Panasonic KX-FL512 and it does not 0 dilying . Pls help me fix this problemAdd a CommentIm using Panasonic KX-FL512 and it does not 0 dilying . Pls help me fix this problem
Im using Panasonic KX-FL423 and it does 0 dilling. Pls help me fix this problemIm using Panasonic KX-FL423 and it does 0 dilling. Pls help me fix this problem
Hello, I have KX MB773 fax machine and it gives me the call service 3 error, but afther I did what it is recomended #9000* 550 and start it is not printing it is just showing P-SF550, what should I do?Hello, I have KX MB773 fax machine and it gives me the call service 3 error, but afther I did what it is recomended #9000* 550 and start it is not printing it is just showing P-SF550, what should I do?
Hello, I have Kx-fl423fax machine and it gives me the call service 3 error, but afther I did what it is recomended #9000* 550 and start it is not printing it is just showing P-SF550, what should I do?Hello, I have Kx-fl423fax machine and it gives me the call service 3 error, but afther I did what it is recomended #9000* 550 and start it is not printing it is just showing P-SF550, what should I do?
Hello,I have Panasonic Dp-MB536 Error is call service 3 How to solve this errorHello,I have Panasonic Dp-MB536 Error is call service 3 How to solve this error
You can't post conmments that contain an email address.
i have a panasonic fax machine kx-fl422 when i switch on it brings call service 2 i need helpi have a panasonic fax machine kx-fl422 when i switch on it brings call service 2 i need help
This is the best solution but error may be remove but its due to THERMISTER Problem, therefore THERMISTER must be changed/checked
Turn ON the machine then press MENU then press #9000* then press 550 then press START and last thing turn OFF the machine or unplugged, then turn ON, its work This is the best solution but error may be remove but its due to THERMISTER Problem, therefore THERMISTER must be changed/checked Turn ON the machine then press MENU then press #9000* then press 550 then press START and last thing turn OFF the machine or unplugged, then turn ON, its work
Fixed mine....but it also never printed anything when it was supposedly suppose too. I also threw in an old used Drum kit I had laying around. I didn't even unplug it....so I'd say at least the first part of it "Cleared" then error 3 code and allowed it to start working again.
Turn on your machine then press MENU then press #9000*then press 550 then press START last thing turn off the machine or unplugged it...This soloution is for KX-FL512 just try it ok?and give me a fee back.
pls help me solve theis problem
service error 2 and service error 3
service error 3
I can not use my fax machine it is giving call service 3 eror.
It doesn‚t work for me. What should I do now?
same problem service call three
I cannot use my printer or fax.
The printer diplays a" service call3"
What should I do
Thanks
JM
2 enter the 550
5 turn on the power
It works....
You made my DAY!
Pentar
eroor code call serves 3
Solved it works Woww
