I HAVE A MAYTAG LSE7800ACW DRYER/WASHER COMBO AND WOULD LIKE TO KNOW WHERE IS THE DRYER BELT LOCATED, PARTS TO BE REMOVED TO FIND IT AND PROCEDURE ON HOW TO CHANGE TO A NEW BELT.
Hi...you can go to the following website and check out how the belt goes on the dryer.
On a front load dryer, you would normally remove the front to expose the drum and belt, after you remove the drum then that exposes the drum rollers, motor, idler arm pulley, etc.
http://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=LSE7800ACW&mfgModelNum=&fkMfgID=1
Hope this helps
