My sons Quickie P320 (dual battery) requires very frequant battery charging lately. The control panel speed indicator bars flash across the display. Any ideas?
Do a load test on battery;'s first to verify batterys r good if they r then check ur battery connections 1 of them is probaly bad i just whent thru this same problem
Rapid discharge usually is a sign of weak batteries, and they should be replaced if the charge indicates that they are full after charging for several hours, and then dissipate rapidly.
If your not getting a full charge indication after several hours, then you need to check the charger to make sure it is putting out about 28 Volts DC. If it is, then it is for sure the batt's.
The sweeping lights should not occur when the chair is off the charger. They sweep while on charge to tell you that it is charging and you can't move the chair. If they sweep while off the charger, turn off and restart and it should go. If not, call a tech. rep. for Quickie.
