Panasonic Lumix DMC-TZ1 Digital Camera Logo
Posted on Sep 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
LUMIX DMC-LS80 SHOWING MESSAGE PLEASE TURN OFF CAMERA AND TURN ON
I RECENTLY BOUGHT A LUMIX CAMERA. IT WORKED FOR WEEK AFTER THAT IT START SHOWING THE MESSAGE "PLEASE TURN CAMERA OFF AND THEN ON AGAIN " EVERY TIME I SWITCH IT ON
Anonymous
Level 2:
Scholar:
  • Expert 96 Answers
  • Posted on Sep 30, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
96
Questions
0
Helped
26652
Points
193
This fault is usually caused by a lens problem.
Over 95 percent of lens problems are from Knock damaged or sand/grit in mechanism. It will need to be serviced by an experienced technician.
Anonymous
Level 3:
Brigadier General:
  • Master 11,967 Answers
Anonymous
Master
Level 3:
Brigadier General:
Answers
11967
Questions
0
Helped
2197854
Points
38521
That message appears when force has been applied to the lens. This usually happens when the auto shut off retracts the lens and the user forgets to actually turn off the camera. Then the camera is placed in a case or pocketbook and the slightest touch of any button re-activates the camera but the lens has nowhere to go.
Where do I find the drivers for my Panasonic Lumix DMC LS80 camera
I found two drivers (noted as Grey or Blue) that allow supported OS versions to read/write to the memory card from Panasonic: http://www.panasonic.com.au/support/downloads/file_type_results.cfm?fileTypeID=1&productCategoryID=16&productID=6566 . Scroll to the bottom of the page for the zip files.
I hope this helps.
My panasonic lumix ls80 digital camera turns itsel*** as soon as i turn it on
Be sure that your batteries are fully charged and in fact using name brand rechargeable batteries. If you are using Alkalaid, make sure they are fresh. Alks after a use that runs them down will come back after awhile for some more pictures. If you have fresh batteries and the camera turns itself off after turning it on, it probably has a problem in the power supply section or the switching section on/off on a circuit board.
Lumix dmc ls80 screen turns to white screen and reads to turn camara of and on again. How can I resolve this "PLEASE HELP!!!"
I have notr seen this camera do this. Make sure your batteries are fully charged. If weak batteries are not the problem it could be an internal problem within the camera. Perhaps you should reset all your menus
1helpful
My camara got wet with salt water and does not turn on.
You probably shorted the circuit when you tried to turn it on before letting it completely dry (could take a week). Besides, salt water will continue to damage even after drying so maybe it's time to think about another camera.
1helpful
Have a message for a locked memory card. We did see the unlock button on the camera by the memory card. Panasonic dmc-ls80
Memory cards have a sliding lock on the side edge...make sure the micro switch is in unlocked positiion.
k
1helpful
Vista will not detect my Panasonic DMC-LS80 digital camera
I reinstalled the software that came with the camera. I restarted the computer and this time the pictures were transferred from the camera onto the computer.
Thank you for your interest and quick response.
1helpful
Digital camera not recognised by windows vista
It may be that the drivers for the Camera are not compatible with Vista. Did you update the Vista drivers.
Can you not detect via USB cable?
Top Panasonic Cameras Experts
ZJ Limited
ZJ Limited
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
