Http://www.homefitnesssolutions.co.uk/manuals/computer_manual_i-run.pdf
This one worked for me today :)
http://www.homefitnesssolutions.co.uk/ma...
Found this one that works today :)
How do i fold away reebok i run treadmill
SOURCE: reebok s9.80 rbtl69608 treadmill - console only
Did you find a solution? I have the exact same issue
SOURCE: how do i lubricant my treadmill
it is an indicator that the belt needs lubricating. turn the power off, and lift up one side of the belt and spray a small amount of lubricant underneath the belt, onto the running board. repeat this step on the other side. turn the treadmill on and run it for a few minutes to spread the lubricant. the oil light should now go off.
this should be repeated every 5-6 months to keep the board lubricated and to reduce friction between the belt and board and will lengthen the life of your treadmill.
