SOURCE: needle thread breaks while quilting on machine frame
I think you might have better luck if you use 40 or 50 weight thread.
SOURCE: Juki HZL-E61: cannot get tension right on straight stitch
Loops on the bottom of the fabric direct the problem to the top thread. Rethread again and make sure the thread goes through the tension discs. Lift the foot, because this is what opens the discs. When sewing and the foot is down, the discs should be closed and thus giving the upper thread the tension it needs.
SOURCE: double needle use on Juki HZL-E80
if the machine regular needle threads front to back NOT side to side, you can use a double needle. simply pass both threads thru all the same slots (thread one at a time so they don't get twisted up) then just before the needles, leave one out of the thread guide just above the needle. you may have to loosen the top tension SLIGHTLY, like a half number. and do NOT use a zig zag stitch without first hand cranking it thru the cycle to be sure the needles clear, or you'll make a 5.00 mistake (the cost of the double needles!)
SOURCE: Needle Thread breaking after about 30 seconds of quilting
Are you threading it correctly? I've had this problem twice, the first few times the thread was wrapped around different items (below the spool holder and then around the needle) the other times I threaded it wrong. Double check that the machine is threaded correctly with the manual. I've missed a step here or there and it does make a difference.
