I cant remember how to program the player 2 remote for the nintendo wii console
Take off the battery compartment for the Wii Remote, and you should see a small red sync button. While the Wii is on, open up the flap for the SD cards, and you should see a red sync button on the Nintendo Wii. While holding the red sync button for the Wii Remote, press and hold the red sync button on the Nintendo Wii. After a few seconds, put the battery cover back on, and test the Wii Remote. Have any questions, feel free to ask. Use the add more details part in your question to ask any more questions. Thank you and have a good day.
To reprogram a wii remote, or program a new one, I first learned that you should try to have all of your other wii remotes turned on.
Then the instructions are as follows:
1. Press the power button on the Wii console to turn it on.
2. Remove the battery cover on the back of the remote. Press and RELEASE the sync button inside the cover. The player LEDs will blink.
3. Open the SD Card Slot on the front of the Wii console. Press and RELEASE the sync button inside the compartment.
4. When the Player LED blinking stops, the connection is complete. The LED that is illuminated indicates the player number.
Yes, poress the sync buttons as indicated, but after releasing sync buttons you must select the controller number by pressing either 1 or 2....this should complete the programming
The Blue lights light up and blink for a while. And then it stops.. any advice
I tried to fix the remote like you said too and it still did not work and I also replaced the batteries in the controller as well and still no luck.
When at a game menu press home button go to i belive controler settings there should be somthing there about connecting click it . i belive you will be able to solve your problem then. sorry i cant help more but i havent used a wii for awhile
Who ever put this post up is a **** not only did I not get my second remote programmed it messed up the first one and now my son is upset....****
^^^^ thats cuz ur a **** it worked perfectly for me
cant seem to get the remote to work
i can't conncet the second remote
wii remote 1 won't connect to the sensor bar
i cant program the second remote for my wii
