I put in a new ink cartridge - and normally the page aligns and then I can print. Now I continually get the message "Carriage Jam - Open door. Clear Carriage jam and then press ok." I've done this several times - no jam - but I keep getting the message. I've shut the printer off and on several times. I've "cold booted" the printer (i.e., pulled the plug, waiting a while to start from scratch). I've tried installing the old printer cartridge (there's a little ink left) to see if it is the cartridge - but I get the same message. Any ideas?? Thanks very much for any help.
The silver bar the carrige slides on has lost all its lubrication. Try putting some chapstick on the silver bar
I’m happy to assist further over the phone at https://www.6ya.com/expert/dan_91204789c5bd4b93
Testimonial: "You are a brilliant god-like person!! THANK YOU SO MUCH!!!!"
I used a bit of sewing machine (or electric razor) oil. I put it on my fingertip & spread it around.
SOURCE: HP officejet 5610 - turn it on and it says
You have a bad printer unit. Uneconomical to have it repaired.
Sorry
SOURCE: HP Officejet 7410 "carriage jam"
SolutionStep one: Perform a power reset and connect the printer directly into the electrical outlet Remove all the paper loaded in the main input tray.
Make sure that the product is turned off.
Disconnect the USB cable from the back of the product.
Disconnect the power cord from the product.
Disconnect the power cord from the electrical outlet and wait 10 seconds.
Reconnect the power cord directly into the electrical outlet and check for the following.
Make sure that the power cord used is the one provided with the product.
If a computer is connected to the product, make sure that the computer is connected to a grounded (three-prong) wall outlet.
Make sure that the power cord is firmly connected to both the product and the power supply.
Reconnect the power cord to the back of the product.
Press the power button ( ) to turn on the product.
Reconnect the USB cable to the back of the product.
If the issue is resolved, proceed to Step six: Print a self-test page.
If the issue continues, proceed to the next step.
for more information please go to below link>>
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458822&cc=us&lc=en&dlc=en
Thanks for using FixYa.
SOURCE: HP Officejet Pro L7800. Had paper jam, but opened
mine was 2 there was paper stuck in the little white gears
SOURCE: how do you clear a carriage jam from an HP
Here's a couple of useful links :-
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01389539&cc=us&lc=en&dlc=en&product=2512010
and
http://www.youtube.com/watch?v=_xLYHteCIBc
1 Turn on the HP Officejet, and then lift open the print-carriage access door.
The print carriage moves into view.
2 After the carriage stops moving, push down on the top of the print
cartridge to release it, and then pull it toward you out of its slot.
Note: It is normal to see ink buildup in the print cartridge slots.
Print-carriage
access door
hp officejet 5500 series
chapter 8
64 maintain your hp officejet
3 Remove the new print cartridge from its packaging and, being careful to
touch only the black plastic, gently remove the pink tape by using the pull
tab.
Caution! Do not touch the copper contacts or ink nozzles.
Once you have removed the plastic tape, install the print cartridge
immediately to prevent the ink from drying in the nozzles.
4 Hold the black print cartridge with the HP label on top. Slide the print
cartridge at a slight angle into the right side of the print carriage.
Press firmly until the print cartridge snaps into place.
Caution! Do not attempt to push the cartridge straight into the slot.
It must slide in at a slight angle.
5 Hold the tri-color print cartridge with the HP label on top. Slide the print
cartridge at a slight angle into the left side of the print carriage.
Note: You must install both print cartridges in order for your HP Officejet to
work.
reference guide
65
6 Close the print-carriage access door. Within a few minutes, a print
cartridge alignment page prints.
