Google Chrome Logo
Posted on Oct 01, 2009
Error101(net::ERROR-CONNECTIONS-RESET)Unknown error i use the google chrome & when i want to go to orkut or any other option it shows the web page is not available & also show error 101(net::ERROR-COONECTION_RESET)Unknown error
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Apr 08, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3575
Points
33
I use the google chrome & when i want to go to orkut or any other option it shows the web page is not available & also show error 101
I have tried everything and nothing works!! Its my favorite browser and it just keeps saying: Error 102 (net::ERR_CONNECTION_REFUSED): Unknown error. Please help!!!!!!!!!!!!
clear your cookies. check for a virus. check firewall settings so that google chrome is allowed. if web pages don't come up in other browsers then the error refers to an internet connection error. reset your router.
1helpful
This webpage is not available. The webpage at...
Refresh the page, it timed out because your connection was taking to long to respond. =)
23helpful
Error 102 (net::ERR_CONNECTION_REFUSED): Unknown error. on both internet explore and crome, but firefox working fine no problem
Sorry, this was too much to explain, so I just copied the error page.
Check the error you're receiving If you can load the webpage using another browser, but not Google Chrome, check the exact error you're getting by clicking the More information on this error link on the page. The rest of the solutions listed in this article are relevant if you're experiencing any of the following errors:
  • Error 2 (net::ERR_FAILED): Unknown error
  • Error 104 (net::ERR_CONNECTION_FAILED)
  • Error 105 (net::ERR_NAME_NOT_RESOLVED)
  • Error 102 (net::ERR_CONNECTION_REFUSED): Unknown error
Check for malware
We've found that malware is frequently the culprit on your computer that's preventing Google Chrome from connecting to a web server. Use free software available through Google Pack to detect and remove malware from your computer. Learn more about removing malware from your computer.
Clear your cookies
Cookies are files created by websites you've visited to store browsing information, such as your preferences for the website or profile information. A corrupted cookie file may be causing this error to show up. Follow these steps to clear your cookies (for Windows):
  1. Click the Tools chrome_toolsmenu.gif menu.
  2. Click the Under the Hood tab and find the "Privacy" section.
  3. In the "Cookie settings" section, click Show cookies.
  4. Click Remove all.
  5. Click Close.
Make sure Google Chrome is allowed in your antivirus and firewall settings
Each program works differently, so check your software's help resources for further instructions.
Adjust your proxy settings
Follow these steps (for Windows):
  2. Select Options.
  3. Click the Under the Hood tab.
  4. Click Change proxy settings. This opens the Internet Properties dialog.
  5. Click LAN Settings.
  6. Make sure that the "Automatically detect settings" checkbox is selected.
  7. Click OK for all dialog boxes.
2answers
SearchSource=10&ctid=CT2269050 Error 102 (net::ERR_CONNECTION_REFUSED): Unknown error. wat to do????
Webpage display issues: "This webpage is not available" (Network errors 2, 102, 104, and 105) Issue This message displays when Google Chrome is unable to find and load the requested web page.
Solutions Check your web address and Internet connection Double-check the URL in the address bar to make sure you're going to the right web address. If you've confirmed that you're going to the right web address, check whether you can open the same web page in another browser, such as Internet Explorer or Firefox. If you can't see the web page in any browser, the web page may be temporarily down. You should also make sure you're properly connected to the Internet.
Check the error you're receiving If you can load the web page using another browser, but not Google Chrome, check the exact error you're getting by clicking the More information on this error link on the page. The rest of the solutions listed in this article are relevant if you're experiencing any of the following errors:
  • Unknown error
To disable the proxy run this from the command line or modify your shortcut to run chrome:
"C:\Documents and Settings\YOUR USER NAME\Local Settings\Application Data\Google\Chrome\Application\chrome.exe" --proxy-server
See here: http://tiny.cc/A2tST
Encountering this problem following your first restart after installing Privoxy (which requires changing G-Chrome's proxy settings).
If, after installing Privoxy, you elected not to have it load on system startup, manually re-loaded Privoxy. Simply reconfigure Privoxy to load on startup and the problem should be corrected.
Click on the following links for more assistance:
Check for malware
Clear your cookies
  5. Click Close.
22helpful
4answers
4helpful
This webpage is not available. The webpage at http://www.google.com/ might be temporarily down or it may have moved permanently to a new web address. More information on this error Below is the original...
1.Go to control panel
2.Click on Internet Options
3.On the top, select the Advanced tab
4.At the bottom of the page, reset all the settings(not only advanced settings, there will be two such reset options)
5.If doesn't fix, try re-installing google chrome or use Apple Safari on Windows(it will work) or use mozilla firefox. You will definitely be able to go online if its only an issue with the browser and not with internet connection.
2helpful
2answers
Error 101 (net::ERR_CONNECTION_RESET): Unknown
That's a browser issue.
Follow the below guide to fix that :-
http://www.google.com/support/chrome/bin/answer.py?hl=en&answer=117804
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Hello For the last 5 or 6 days, I've been getting this error msg whenever I try to open this page: ERROR: Error 101 (net::ERR_CONNECTION_RESET): Unknown Error WebPage:...
Orkut is one of the product of Google. It is better in Chrome. the "err_connection_reset" comes under delay of page accessing so check it out your browsing speed. and check any "spy look" on your system while accessing the orkut [social web]. Make sure of fine availability of processor time, browsing speed along with chrome settings.. if you got the same, then notify the error message with out error.have fine
3helpful
5answers
Unable to work with google chrome
Google Chrome CRASHED.
Uninstall and reinstall Google Chrome and it would fix the issue.
Thanks.
Its showing the message thar error on page after signing
You need to make a check on these
  • Make sure you are not using an older version of internet explorer [Try Google Chrome].Or simply update to the latest one.
  • Make sure that your browser is allowing cookies this is how u do it
    1. Go to the Tools menu and select Internet Options.
    2. Click the Privacy tab.
    3. Click the Sites... button and type www.orkut.com in the 'Address of Web site' section. (You won't see the Sites... button if you choose 'Block all cookies.
    4. Click Allow
    5. Click OK.
  1. This would solve the issue.
Top Google Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Kolbrun...
Are you a Google Computer and Internet Expert? Answer questions, earn points and help others
