Hannspree HT09 28 in. LCD TV Logo
Posted on Oct 02, 2009
Can't get my hannspree remote to work with comcast
Can't get my hannspree HT09 tv remote to work with comcast cable box
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 01, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
5470
Points
25
10030 for the comcast dvr remote. Code is from NEC
  • jtech2000 Mar 20, 2011
    Correct answer 100% Thanks.
  • Anonymous Jul 04, 2013
    The V chip is locled and I'm being asked for a password.
Anonymous
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Jun 13, 2010
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
0
Helped
8514
Points
13
My Comcast Motorola STB's (Set Top Box) DCT 3412 / 6412 remotes did not support the new Hannspree 28" TV remote codes. Then I discovered the Hannspree TV remote was universal and had a button for Cable. Holding down the Cable buton I programmed in the Motorola VCR code 0050 and now my Hannspree remote controls the Comcast STB. Now I use the TV remote to control both Comcast Ste Top Box. PeterC
Hannspree 28" tv video shuts off after on for a few minutes
It sounds that the fault is with the connections that goes to panel from its T'Con board. Check all the flat cable connections. Re-seat them once.
Atualizacoes hannspree ST251MAB
What is the problem you faces with this TV? Provide more details please.
Hdmi1 has no signal
Use HDMI 2. This T.V. is unlikely to have replacement parts because it is not a mainstream TV. (Samsung, Panasonic, etc..) Make sure your HDMI cable is good too and your cable box or what ever other device you're using is properly connected and on.
1helpful
2answers
Trying to incorporate my Hannspree remote with my cable remote as to use just the cable remote......? Thanks, ph
Hi, unfortunately the only way to use your particular brands remote with your cable companies remote is if the cable remote has what's called a "LEARN " key. This is used for cloning another remotes codes to the cable's remote. Unfortunately most tv suppliers don't provide their codes for universal remote use. The first thing i would do is contact your cable providers customer assistance to see if they have setup codes for your brand. then if that doesn't work then you can always buy a universal remote with a " LEARN " function, enabling use with hanspree tv as well as current cable box. I hope this was helpful and thanks, let us know how we did, Good luck ,Prodzilla
Trying to program Dish Network remote
Hello, this is a simple issue to fix!!!! follow these simple steps from our website, and that remote will be working right away!!!!! Now, to program your remote to the TV, you will want steps 6 and beyond. And all steps 1-5 are for programming the remote to the receiver. Hope this helps!!!!!!!!!!!
http://www.dishnetwork.com/SupportSection/remote-setup
Becki Barned
DISH Network Customer Service
50helpful
4answers
Cannot program comcast remote to work with hannspree lcd tv 25"
try this
press tv button (lights up red)
hold setup button for 10 seconds (tv button blinks twice)
enter code 10030
Press power button on top right. If tv turns off your good
If it doesnt work follow steps above but try these other codes 11348, 11745, 11783
TV doesn't receive signal
Faulty Video boards If you bought it in May then rapidly get it fixed under warranty or exchange it for a better brand. Who is Hannspree? not well known and may be cheap Korean TV with no parts available
Please rate our help to keep FREE service online++++Thanks for using FIXYA
Top Hannspree Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Hannspree Televison and Video Expert? Answer questions, earn points and help others
