All buttons, except power, now only control tv/video. Menu drops down if you hold it, if you let go it does tv/video. Remote does not work even with new batteries. Cannot change channels or volume up/down.
Most RCA sets use a
four digit code to control the v-chip. The code reset is different depending on
the model. Try each number until you find the one that works for you.
1.
Hold down the
MENU button on the remote and VOLUME DOWN button on the TV it's self at the
same time for at least 4 seconds. The set won't say so, but the lock will be
unlocked
2.
Hold down the 0
(zero) button on the remote and the VOLUME DOWN button on the TV itself at the
unlocked
3.
Hold down the
MENU button on the front of the TV and the TV button on the remote at the same
time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU
button on the front of the TV at the same time for at least 4 seconds.
On blu ray remote control hold down TV Power+01 at the
same time. If the TV turns off the controller is programmed. If not, try TV Power+02,
+03, +04, +05, +06, +07, +08, +09. Different TV BRAND??? ...TRY http://remotes.com/remotes/documents/Samsung/AK59-00104K.pdf
