Check the ports thr' control panel-if driver for usb port is missing pl. reload usb driver.check with pen drive whether the usb port recognizes the pendrive as it flashes the light on the pendrive.
You must have a connection cable to your computer (USB ). just plug it and your computer recognize it automatically as external Hard disk..than copy the files and paste it into PC..good luck.
Have you tried the cord from your camera to your computer's usb port? It should be recognized by the computer, allowing you to transfer your videos to a folder. The camera has a built in memory, so you have to use a cord to transfer the movies and pics.
Insert the recording media containing the pictures into the camera.
Depending on your camera, set the USB Connection or Transfer mode setting in the menu to the Mass Storage , Normal , or PTP .
Use the USB cable supplied with the camera to connect the camera to the computer. IMPORTANT:
Connection
through a USB hub or other USB device -- such as a printer or keyboard
-- is not supported and cannot be guaranteed. Connect the camera
directly to a USB port on the computer.
If the USB connection
from the camera is not recognized by the computer, disconnect the USB
cable and repeat steps 4 and 5 using a different USB Connection or Transfer mode setting. If the connection is still not recognized, further troubleshooting is available.
NOTES:
The computer will automatically install the USB driver for the camera.
When the camera connection is established, an AutoPlay window will appear.
In the AutoPlay window, click Import pictures .
In the Importing Pictures and Videos window, click the Import button. NOTE: After the pictures have been imported, the Windows Photo Gallery window will appear and display thumbnails of the imported images.
If this doesn't work there is an updated driver available
Turn off the CPU unplug the power cable and all usb cables, let it sit for about 15-20 minutes. Plug power cable back in, turn on CPU, plug in your usb devices.
I had a problem like this -- tried plugging the camera in to the rear USB slots not the front ones and it worked fine.
I think that it doesn't like going via a USB hub, but wants a direct connection. All of the USB ports on my computer are connected direct to the motherboard (i.e. none are on PCI cards or anything), but looking at the hardware info for the computer, it looks like the motherboard has a few "direct" USB connections, and then an on-board hub which the front ports connect to. If your computers are the same, that would explain things. I'd suggest trying each USB port one at a time (turn the camera off before plugging in, and back on when in) and see if one of them works. Wouldn't hurt to power the camera from the mains at the time too.
u just insert the wire properly tothe usb driver and keep on adjust the the wire in ur mob till it will recognise...tis pro may be cause due to loose connection between mob pin and data cable pin
If it is a JVC digital camera (DVC or hard drive) you need to have the camera set to the "Play" mode, and turned on before plugging in the camera. Vista should recognize it as a digital source afterwards. You need to have a firewire or USB cable for the camera, and the port it plugs into needs to be recognized. Be sure you don't have an unrecognized device in /Control Panels/Device Manager/
