Fusing thermistor open
Fusing thermistor disconnected
Fusing thermistor connector defective
Fusing thermistor damaged or warped
Fusing temperature 15% less than the
standard input voltage.
Change the thermistor.
Here the reset procedure that is done through operation panel: press "Clear Modes" botton,then 107,then press and hold the "Stop" key for 3-5 seconds until you see the screen has changed.After that you need to turn the main power swith off and back on.The error code should be reset at this point.If it comes back,you may have a bad thermistor,bad fusing lamp or a bad connector.
