Make sure thers nothing stuck in the pump and the pump is not faulty.somtimes a coin can get stuck in the drain hose causing it to not drain intermittently
lower the drain hose past the tub level and the water will drain out
if inside use a bucket to collect the water
when empty switch off the taps and use the spin cycle to dry the clothes
Just got Hoover 700 la manual top loader 2. hand...it is taking maximum amount of water on low arrange, and takes an hour on delicates. it also spin dries very strongly, just ruined my clothes..what you would suggest folks.. cheers aysh
These are a great little machine,I dont know why they have to go changing things.Anyway this sounds to me like the timer.It fills & the water cuts off so the inlet valve is ok.It drains so the pump is ok.It spins so the motor should be ok.Try it on other cycles like gentle or delicate & see if it agitates.I'm sure it will be the Timer.
Valve blocked in rear of drum. Switch off power supply before cleaning. If the problem still occurs it could possibly be the brushes in the motor. both jobs are simple and very cheap to repair
Probably very repairable but impossible to say how much without looking inside and fiddling around and checking a few things.
Fault could be caused by several possible faults at widely varying cost.
I suggest you call a friendly local white appliance engineer...
