The pedestals bolt into the bottom of the washer where the legs where.
This is definatly a heavy job, so it's best to get 2 more people to help you out.
#1 Remove all 4 legs that came on the washer factory.
#2 Make sure you have enough room to manouver the machines. The washer is going to be the most difficult so start with it.
#3 Have your friends tilt the machine back and you slide the pedestal under the machine.
#4 Kneel down infront of the machine to prevent it from sliding forward.
#5 Have your friends lift up the back of the machine and walk it forward until the holes in the top of the pedestal are in line wiht the holes from where the legs where.
#6 Thread in the bolts and tighten.
**You will need to take out the drawer of the pedestal to get the back bolts in. There are plastic clips on the inside of the runners, just push those down at hte same time and pull the drawer**
Good luck! Please let me know if this was helpful!
SOURCE: Front Load LG Washer and Dryer Pedestals
If the pedestals are properly installed they pretty much become part of the washer and dryer and if those are installed correctly you will have no more vibration then if the units are sitting on the floor. If possible get the washer as close to an outside wall as possible since the floor is stronger there.
SOURCE: kenmore pedestal for the front loading elite washer and dryer
some pedistals have a screw on drawer just behind front on end of rail newer ones have a small black lever on each side ..pull drawer completely out lever is about midway at end of inner rail pull lever 1 up other down drawer will pull off rail reinstall by sliding rails back together and pusing all the way in
SOURCE: Installing pedestals for washer and dryer
its not but it is a 2 person job, the washer is in excess of 200 lbs and must be lifted onto the pedistal, after that its just a few brackets and philips screew to secure it.
SOURCE: I have front loading washer/dryer;need to install pedestals.
Yes!!!! Do not lay the machines on their backs with out the shipping bolts/hardware installed..Major damage will occur!!!!!
clarkco
SOURCE: kenmore front load he3 washer: door wont unlock
happened to me once - I just unplugged the machine - waited a minute and plugged it back - it - then used cancel button
