Question about Gateway ML3706 Notebook
My gateway laptop will not turn on when you push power button.
My gateway laptop will not turn on when you push the power button even though there is power to the machine and the screen works just fine,i get the light that i have power but no matter how hard you push the power button it will not turn on at all. The modle number for my computer in case anyone needs it is. ML3706
I tried contacting gateway support but they were no help at all. I really need my computer for school..
  • 1 more comment
  • thisxorxt814 Oct 04, 2009
    it doesnt even turn on its as if im not even pushing the power button but i get the light in front that tells me theres power to the laptop.
  • For Old Hack May 11, 2010
    Pull the battery, and have it plugged into the wall. Sometimes the battery, if dead, can prevent a laptop from starting. True of IBM/Levono/HP/Dell not true of Sony/Apple. Let me know what happens. When you do hit the power with no battery, does the fan spin? Does the HD start spinning? Does the HD sound like its reading?
  • maryanej_mon
    maryanej_mon Dec 02, 2012
    my gateway laptop does not power on no matter how i push the butto,what;s wrong with this.I heard somewhat like HD sound reading? pls need some help.
  • 20 Answers
If you power it on and get the light it means either two things:
1. It needs a minimal charge on the battery to power. ( havent seen this since the old Compaq/Apple stuff ) or
2. The motherboard is fried. ( Just diagnosed a HPDV6000r special edition with this beautiful computer, dead motherboard ).
What is the warranty like:
NOTE TO ALL STUDENTS: Buy New laptops in November, so the warranty comes up in October, after you know you need more computer or repairs!
Posted on Oct 04, 2009
    New Friend:
I have the same problem with the power switch. if you disconnect the battery from the laptop and immediately reconnect it, the power button works...it is an annoyance but at least the laptop is operable., i might return mine because it is within the warranty period
Posted on Oct 24, 2009
6ya staff
SOURCE:
Lost power button got turn off
try this; carefully detach (pull off) the front panel of the base tower unit.. and behind the plastic front that you just took off there's a little button that you can push to power off and on. The power button just goes through the plastic cover and pushes the button.
Jan 04, 2016 | Gateway Computers & Internet
Gateway laptop NV52L03h power button doesn't turn on and got apart?
U need to replace the power but to resolve the issue you have.
Sep 04, 2015 | Gateway Computers & Internet
Where is the battery button to reset the bios on a Gateway laptop model #400SD4 located?
just pull that battery off the board for a couple minutes, the also may be a little button you will be able to push on the board
Jan 25, 2013 | Gateway 400SD4 Notebook
Gateway laptop i push power button it wont boot up but leds in front flash 4 times
Try holding down the power button instead of just pushing it. I had this problem with my HP dv7 and holding the power button down for around 5 seconds worked for me. Also make sure that its plugged in to a power source.
Oct 23, 2012 | Gateway Computers & Internet
Gateway nv52 won't turn on
I also had this problem. I turned it off and it would not turn on. I found the solution. First, extend the laptop screen as far back as it will go. Don't just stop the screen at a ninety degree angle. My laptop screen pulls back to about 135 degrees. Now press the power button. It should start up.
Why do I think this works? Well...I used to own an older model thinkpad that had a short "male" connector on the screen, that when the screen was folded down would enter into a "female" connector on the base of the unit and trigger sleep mode on the unit. This is how the system could automatically hibernate when the screen was closed. The little male connector broke off, and I couldn't get the system to wake up, because the connection to tell the laptop that I had the screen up or down no longer worked. I couldn't even power it up. I had to take an ink pen and push the connector through the female end to indicate to the motherboard that I'd opened the screen before it would even turn on.
It appears that the same type of mechanism is built into the long BAR under the screen of the NV52 and somehow it can't determine when the screen is open or closed. If it detects that the screen has not been opened, it won't power up. This safeguard prevents the laptop from being turned on mistakenly while closed up in your laptop bag. Extending the screen back resets the mechanism and it should turn on. Sorry for the long explanation...
Jan 15, 2010 | Gateway NV5215u Notebook
Gateway 500xl pc will not turn on power button is lit up yellow
A LOT of Gateway computers will go into this catatonic state because of a dead battery. The battery is on the motherboard -- it looks like a metal disk about 1" in diamter. Check it or replace it. This applies to laptops too (not the actual laptop battery, the CMOS battery -- a laptop will have one on the motherboard too)
Hope this helps
Mar 13, 2009 | Gateway 500XL PC Desktop
Accidentaly pushed the hibernation button on my gateway GT 5408
Hold the power button for 3 seconds until it turns off... hopefully this doesn't mess XP up...
Dec 18, 2008 | Gateway (2900147) PC Desktop
Wireless connection problem, I have a gateway T1631 laptop. I cant see any network within the range even though I place d next to the router, but I can connect to the internet through the ethernet drive.
I have seen this issue alot of times. Please make sure you wireless card is turned on. Sometimes the switch is on the front or the sides or you may have to push a function button + a wireless button. Take a look at you owners manual to be sure
Aug 17, 2008 | Gateway Computers & Internet
Gateway ML3706 Notebook Logo
1,642 people viewed this question
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Thomas F. Schneider
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
