If your Beko WMB81242LW washing machine is stuck on the spin cycle and won't change programs, here are a few things you can try:
Check the door: Make sure the door is properly closed and latched, as this can sometimes cause the machine to get stuck in one cycle.
Reset the machine: Unplug the machine from the power source for a few minutes and then plug it back in. This will reset the machine and may clear the issue.
Check the control panel: Make sure the control panel buttons are working properly and not stuck in one position.
Check the control board: The control board could be the cause of the issue, especially if your machine is 6 years old. A malfunctioning control board can prevent the machine from changing cycles.
If these steps don't work, it's best to have a professional repair the machine
Hi just read your posting.Now is your machine draining the water?Could you please supply the model number for me.Please reply with additional information and I am sure I can help you rectify this fault.Looking forward to your reply.
One looses touch with all the codes available, but normally if washer stops mid cycle its due to a blocked or faulty drain pump. OR incomming water is to slow or defective inlet sensor. Switch off and start from the beginning. See if you can get machine to drain by moving the timer etc. If not, rectify pump problem. Take note where in the cycle the problem arises.
Hi just read you posting.Now I need the make and model of the machine.If it is a Fisher and Paykel then the diverter might be stuck in the recirculate position.Also, is your machine draining into the laundry sink or somewhere else?Please reply with additional information to the questions and I am sure I can help you rectify this fault.
If your ariston amd129 shows DEMO on the display chances are you put it on that program.To rectify press on/off AND program start button simultaniously for 30 seconds.
These Orions and the Emerson units built by Orion all revert back to set up after being unplugged for a given length of time. The situation can be rectified on the front panel without the use of remote. Please forgive if this seems over-simplified:
1. Turn on the set.
2. When screen appears push "FF" or "REW" button to select the desired language.
3. Push "PLAY" to move the arrow down to "Auto Preset".
4. "FF" to engage the auto channel programming.
5. When the set is done auto-programming the menu will clear and you use the set normally.
the pump is under neathe in the casing
you will have to turn machine on side for this to get at pump make sure to disconnect everything first
i will drop a picture what it closley resembles you have naterial stuck in this or your drain hose kinked if you have something stuck in this pull it out the way it went in threw inlet with large needle nose pliars
