MY SIDE BY SIDE WAS WORKING ON AND OFF FOR A WEEK. NOW MY FREEZER IS THE REFRIG AND MY REFRIG IS A HOT BOX. CAN YOUHELP?
The return air ducts are iced up and need defrosting, empty the fridge and freezer and unplug for 3to 4 hours with the doors open
Testimonial: "WAS this helpful? It sure was.You guys know jusy what to do to fix our problem.Our side by side works like new. I thank you and my family thanks you. "
SOURCE: Have Maytag side by side
the notorious Adaptive defrost did it again (lol) verify the condition of the heater putting a voltmeter on the "beeping" feature if it beeps its good.
Replace the Adaptive Defrost board and defrost thermostat and should work like a charm
SOURCE: MAGIC CHEF CTF1920ARA - Freezer works, Refrig. portion does not.
Sounds like a defrost problem. Check to see if
there is any frost buildup in the back wall of the freezer. If so, it is not
defrosting as it should.
If you don’t know what these are then unplug the machine and let the ice
melt in the freezer overnight with the door open. Then try it the next day, if
is cooling fine then you need to have a service person replace one of the above
items.
SOURCE: Freezer not freezing, frig not cooling
I had a problem with a side by side fridge once, not getting cold on either side.
Turned out to be the compressor....so, that might be your problem too.
There is also a possibility that it could be the thermostat, most parts can be ordered on line, and delivered right to your door. Sometimes a repair guy will come to your house and install, it saves you money, because some of the parts have about a 300 percent markup when brought to your home from a repair shop.
Good luck!!
SOURCE: line and air flow box between freezer and frig
If the fan is running in the freezer compartment, temperatiure is normal, and no frost is building up on the back panel in the freezer panel, then there is a good chance the return air shutes in the fresh food compartment are blocked with ice. The return ducting is just as important as the the supply shute which you melted out. Difficult if not impossible to see.
My recomendation is to empty, unplug and air dry the whole machine preferably with a fan blowing air into the fresh food compartment.
Haste makes waste with this machine. Using heat can cause the plastic shutes to melt and distort.
Should be defrosted in this manner for 24 hours.
Restart and give the machine 24 hours to recover. Common problem with Whirlpool products.
P.S. Check to see if lights go out when closing fridge door. In fact this should be your first step. Jack
SOURCE: 10 year old refrig cools only if freezer temperature is on maxium
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
