My car has a keypad unlock code on the door but I can't seem to work the code. There are 5 buttons, each has two numbers on it (1-2)(3-4)(5-6)(7-8)(9-0),my code is 18839 and i can't get it to work. Is there a way to reset the code or change it? or am I doing something wrong? also my trunk will not pop with the key remote. and will not unlock or lock unless I'm 5 feet from the car.. which isn't a big deal but I know they usually work from a much larger distance.
It's in owner manual. But, first you have to enter your original code and it must work. then you press the 1 button and then enter a new 5 digit code, then press the 1 button again.
Keyless Entry Keypad
To unlock the driver front door (20124) , and disarm the anti-theft alarm control (19A366) , (if equipped):
Enter the permanent factory code.
Enter the owner's alternate code.
To unlock the passenger door(s), press the 3/4 button within five seconds of unlocking the driver door or luggage compartment.
To unlock the luggage compartment door (40110), press the 5/6 button within five seconds of unlocking driver or passenger door(s).
To turn on the courtesy lamps and light all illuminated components, lift either front door handle (22404) or press any button on the keyless entry keypad (14A626) .
To lock all doors, press the 7/8 and 9/0 buttons at the same time with all doors closed. (It is not necessary to enter the key code first.)
This will turn off courtesy lamps and arm anti-theft alarm control (if equipped).
To program an alternate code:
Enter the five digit permanent entry code into keyless entry keypad .
Within five seconds of pressing last button of permanent code, press the 1/2 button within five seconds of pressing the last button of the permanent code.
Enter any alternate five digit code within five seconds of pressing 1/2 button.
Enter a sixth digit as follows to indicate operator's memory seat setting to be set by alternate code:
9/0 — no memory recall
1/2 — memory seat position 1
3/4 — memory seat position 2
5/6 — memory seat position 3
After successful programming, the doors will signal by locking and then unlocking.
Keyless Entry Keypad Does Not Work Properly
Circuit.
Keyless entry keypad.
Electronic door lock control processor.
Open Fuses:
Town Car and Crown Victoria/Grand Marquis
Power Distribution Box (under hood)- K, 40A (Maxi)
Open the right/rear door. Fold the right/rear seat down. Carefully pull the trim panel where the right/rear seat belt pivot/height adjuster is housed. Once removed, pull the trim panel below that in order to expose the Vehicle Security Module (the module that controls the electronic locking system for your vehicle) that has the three electrical connectors plugged into it. The connectors are colored green, grey, and blue. On the module there is a label with the engineering number similar to 5L2T-15K602-EA. You will also see FIVE large numbers. Those FIVE large numbers are your Keyless entry keypad code. Once you know your keypad code, you can test its operation by first entering the FIVE digit keypad code to unlock the driver door, and then pressing the 3/4 button within 5 seconds to unlock ALL doors. Pressing the 5/6 button within 5 seconds after entering the code will unlock the liftgate glass. Pressing the 7/8 and 9/0 buttons simultaneously at any time will lock ALL doors. Hope this helps.
1. Enter 5-digit permanent entry code into the keyless entry keypad. 2. Within 5 seconds of pressing last button of code, press the 1/2 button. All doors will lock then unlock confirming you are in programming mode. 3. Press any button on first Keyless Remote within 5 seconds of pressing the 1/2 button. Locks will cycle to indicate succesful programming. 4. If you are programming more than one Keyless Remote (Including any exsiting remotes) Press any button on second keyless remote within 5 seconds of previous remote. Locks will cycle again to indicate succesfull programming. (If the keypad light goes out before all remotes are programmed the entire process must be repeated). 5. Press the 7/8 and the 9/0 buttons simultaneously on the keypad to exit program mode.
You will need the original factory programmed keyless entry
keypad code to program your own code. To locate the original keypad
code, open the right/rear door. Pull the on-body rubber weatherstrip
out, around the rear side of the door closure. Fold the right/rear
seat back down into the locked position to facilitate access to the
right/rear seat belt anchor. Carefully pry the upper plastic panel that
houses the height adjuster and seat belt anchor off the body taking care
not to damage the panel. Now pry the lower panel outward just far
enough to enable access to the Vehicle Security Module, where you'll see
plugged into it, colored green, gray, and blue. On the module will be a
series of digits on a label similar to 2L2T-15K602-EA. Beside those
digits are five numbers. Those five numbers are the key-less entry keypad
code. Once the original keypad code has been obtained, you will need to
enter it, press the 1/2 button within 5 seconds to activate the
programming mode. Holding the 1/2 button for more than 2 seconds after
activation will erase the the code you programmed. The existing code
will not need to be erased to program a new code. Within 5 seconds,
enter the new 5-digit keypad code. The door locks will lock and unlock to confirm the new code is programmed. Hope this helps Tim
Pretty simple really. all you need to do is enter your code into the keypad located on the vehicle (the code to unlock and lock the doors/the normal code you always use). Then press the 1/2 button on the keypad. then just press one button on the remote. Your doors should lock and unlock to let you know the programming was a success. If you are doing more then one remote press the other ones within i think 5 seconds to program that remote as well. I hope this helps and good luck.
Reinstall your own code,if the preset works and you still have the little instruction card. If not let me know,I'll look at mine and go over the service manuals
. Enter 5-digit permanent entry code into the keyless entry driver door keypad.
SECTION 501-14B: Keyless Entry/Computer Operated Locks
1999 Town Car Workshop Manual
GENERAL PROCEDURES
Programming —Keyless Entry Keypad Code
Enter the permanent factory keyless entry keypad code.
Press the 1/2 button within five seconds to activate the programming mode. Holding the 1/2 button for more than two seconds will erase all stored customer codes. The existing codes do not need to be erased to program new codes.
Enter the new five-digit keyless entry keypad code.
To associate the new code with personality positions 1, 2 or 3, press the 1/2 button within 5 seconds of entering the 5th digit of the new code for position 1 or 3/4 button for position 2 or 5/6 for position 3. The door locks will lock and unlock confirming the new code is programmed.
If another code is to be programmed, begin entering the code within 5 seconds of the last button pressed.
After all new keyless entry codes are programmed:
Press keyless entry keypad buttons 7/8 and 9/0 at the same time to exit the program mode.
Wait for 5 seconds; the driver door module (DDM) will exit the program mode automatically.
Cycle the ignition from OFF to RUN four times within three seconds. The locks will then lock and unlock, confirming program mode has been entered.
NOTE: When the first keyless entry remote transmitter is programmed, all other keyless entry remote transmitters are erased. Press any button on the transmitter to be programmed.
If additional keyless entry remote transmitters are to be programmed, repeat step 2 within 7.5 seconds.
To exit program mode, turn the ignition to START or wait 7.5 seconds.
Programming —Remote Memory Activation
NOTE: This procedure must be completed within 5 seconds.
Press the SET button on the driver door panel.
Press any button on the keyless entry remote transmitter to be associated with a memory setting.
Press the 1 or 2 memory button on the driver door panel.
Programming —Autolock and Horn Chirp
NOTE: This procedure must be completed within 30 seconds. Turn the ignition switch to RUN.
Press the UNLOCK button three times.
Turn the ignition switch to OFF.
Turn the ignition switch to RUN. The doors will lock and unlock to confirm entry into program mode.
Press the UNLOCK button once to toggle the Autolock feature on or off, or twice to toggle the Horn Chirp function on or off. The horn will chirp to confirm toggling of the Autolock feature.
Exit program mode by turning the ignition to OFF, START, or wait 7.5 seconds.
Enter the permanent factory remote keyless entry (RKE) keypad code.
Press the 1/2 button within 5 seconds to activate the programming mode associated with the memory position 1 settings. Holding the 1/2 button for more than 2 seconds after activation erases the stored personal code.
Within 5 seconds, enter the new 5-digit RKE keypad code. The door locks lock and unlock to confirm the new code is programmed and associated with the memory position 1 settings. Entering any new personal code automatically erases the old personal code.
Press the 3/4 button within 5 seconds to activate the programming mode associated with the memory position 2 settings. Holding the 3/4 button for more than 2 seconds after activation erases the stored personal code.
Within 5 seconds, enter the new 5-digit RKE keypad code. The door locks lock and unlock to confirm the new code is programmed and associated with the memory position 2 settings. Entering any new personal code automatically erases the old personal code.
Press the 5/6, 7/8, 9/0, 7/8 and 9/0 button within 5 seconds to activate the programming mode or allow the system to timeout.
Within 5 seconds, enter the new 5-digit RKE keypad code. The door locks lock and unlock to confirm the new code is programmed. Entering any new personal code automatically erases the old personal code.
Adding and Removing remote Keypads to the Smartlock module ------------------------------ Up to four Keypads can be programmed and used with the Smartlock Remote Central locking system. If you have replaced the BEM, or new keypads are being added to the system, you will need to train the keypad codes to the module. # 1. The ignition switch should be in the Off position, with all the doors shut and Unlocked. # 2. Turn the ignition key to the ACCESSORY position and within 5 seconds, operates the rear demister switch exactly three times in quick succession. (IE. Press the switch so the Demister light turns on, then off, then back on again.) # 3. After the 5 seconds is up, the door locks will change state, to indicate that the BEM has entered keypad learn mode. NOTE : All existing keypads at this point, have been erased from memory ! # 4. Press either buttons on the keypad that is to be trained. The door locks will change state twice, to indicate that the keypad has been added to the BEM memory. # 5. Follow step 4. for each keypad that is to be added to the BEM memory. A maximum of 4 keypads can be added to the BEM memory.NOTE : You must teach all remote keypads for the Smartlock module, before proceeding. # 6. When you have taught all the remote keypads, turn the ignition to the Off position to leave the learn mode. The door locks will change state to indicate a return to normal mode. # 7. Check the function of both buttons on each keypad, to ensure that the keypad has been trained.
