321studios DVD X Copy Express (200083) for PC Logo
Anonymous Posted on Oct 04, 2009
WILL NOT LOAD IN WINDOWS VISTA
DVD EXPRESS WILL NOT LOAD IN WINDOWS VISTA . DVD EXPRESS CAN NOT FIND DRIVERS, THEN A MESSAGE COULD NOT LOCATE PATIN-COUFLIN ENGINE?????
Anonymous
Level 3:
  • Master 403 Answers
  • Posted on Oct 04, 2009
Anonymous
Master
Level 3:
Answers
403
Questions
0
Helped
135647
Points
1103
This is the requirements for DVD Express. There are a lot of programs that are not compatible with Vista.
Minimum Requirements
  • Windows XP, 2000, 98, ME
  • Pentium II 450 MHz processor
  • 64 MB of RAM
  • Hard Drive free space of 10GB
  • DVD Burner (DVD-R, DVD+R, DVD-RW, or DVD+RW)
  • Blank DVD Media (DVD-R, DVD+R, DVD-RW, or DVD+R
http://www.dvdcloningsoftware.com/dvdxpress.htm
You might consider to partition your hard-drive so you can run XP on it too and be able to run programs like this one. Hope this helps, sorry for you luck. Let me know if I can help you with anything else.
JimmyC
Testimonial: "Thank you...Nothing is ever simple."
WINDOWS VISTA 64 bit not reading CD Rom/ DVD player after services pack download. Driver is best. Error message "problen in registry (code 19)
If it truly needs a driver then install patin-couffin It will bypass all that windows uses now and accurately talk between drives and the dvd-rom. But it sounds to me that your dvd-rom just failed. You never know when they are going to go
Intel DQ965GF Motherboard won't load WIN OS (WINXPPro volume disk or Win7) tho an old Dell disk did load. Is there a fix? Thz
Hello here is the homepage:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+965+Express+Chipset+Family+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+DQ965GF
Windows 7 is not a supported system, but you can use the drivers from the vista system, but only the 32 bit.
Turn on or restart your computer and watch for a message during the post about a particular key, usually Del or F2, that you'll need to press to ...enter SETUP. Press this key as soon as you see the message.
After the post, BIOS will attempt to boot from the first device listed in the boot order.You need to change that, so the first boot device in the list is the dvd drive. If that device is not bootable, BIOS will attempt to boot from the second device listed, and so on.
Note: The boot order is a BIOS setting so it's OS independent. In other words, it doesn't matter if you have Windows 7, Windows Vista, Windows XP, Linux, or any other PC operating system on your hard drive or other bootable device, these boot sequence change instructions will still apply.
Here is how you do this:
http://www.hiren.info/pages/bios-boot-cdrom
But ofcourse there could be a problem with the dvd drive or harddrive.
To install windows 7, you will need at least 1 gb ram or more, and a dual core cpu.
Best of luck
2helpful
2answers
Code19 on sony cdrwdvd willnot reconize on inspiron 1525
Your CD drive or DVD drive is missing or not recognized by Windows or other programs, so you cannot play or access a CD or DVD. This issue might have occurred after you installed, uninstalled, or updated a program or Windows Vista.
This issue may have occurred after one of the following situations:
  • You upgrade a computer to Windows Vista or install Windows Vista Service Pack 1.
  • You install or uninstall CD or DVD recording programs.
  • You uninstall Microsoft Digital Image.
You may see one of the following error messages:
  • One of the following error messages appears when you view the CD drive or the DVD drive in Device Manager.
    Error message 1 The device is not working properly because Windows cannot load the drivers required for this device (Code 31). Error message 2 A driver for this device was not required, and has been disabled (Code 32 or Code 31). Error message 3 Your registry might be corrupted. (Code 19)
  • An "error code 39" error message.
  • A message that resembles the following appears in the notification area: Windows successfully loaded the device driver for this hardware but cannot find the hardware device. (Code 41)
  • you can find this information and more at this site..
  • http://support.microsoft.com/kb/314060
Tsst corp cd/dvdw ts-652d ata device not found
your CD-ROM/DVD-ROMs require no drivers   install Nero and see if it works  if not  check the wiring  if it has IDE cables make sure the jumpers are correct for the situation  make sure they are 80 pin cables not 40 pin and that the poer is plugged into the drives  sometimes if Patin-couffin is installed it may fix things
Wot is a patin couffin engine
The "VSO Devices" category belongs to VSO Software, they make DVD "Back-Up" software and their Patin Couffin engine is widely used by other like-minded software houses.
What is patin coffin engine
patin couffin engine is the correct spelling....it is a device driver. It is used for burning DVD's.
also known as a software engine....its produced by a french company called VSO. Try this link....
www.vso-software.fr/products/burningsdk
there are a few issues with this engine, so download at your own risk....hope this helps, dont forget to rate me...thank you
XFX 750I Motherboard w/ SLI Can not locate the SATA Driver ( Can not load WIN-Vista ) Help
You will get to a point in Vista set up where it asks you what drive/partition you want to install to. Obviously the window which should contain the drive information is empty because Vista can't see the hard drive yet. At the bottom of this windows there's a "Load Drivers" button. Make sure your XFX motherboard CD is in the dvd drive then click the Load Drivers button. Now you should be able to browse the CD. The SATA drivers will either be in a folder called RAID or a floder called SATA. Just click on the correct folder containing the drivers and click OK. Vista should now load the SATA drivers and your drive/s will appear in the window.
If this doesn't work then I suggest you register on XFX's website and go to the support section and download the driver from there:
http://www.xfxforce.com/en-gb/Help/Support.aspx
DVD burn with DVD X-copy not completing finalizing mode
"Is this what is causing the "finalizing" to not complete the burn?" ... Almost certainly yes. You need to update/reinitialize your Patin Couffin engine device drivers(s).
Referer: http://www.free-codecs.com/download/Patin_Couffin_access_layer.htm
Download: http://www.freecodecs.net/fc/patin-couffin_37.zip
  1. Download the stand-alone installation package.
  2. After download is complete, close all other applications, then run it.
  3. Restart (reboot) your system.
  4. Test by re-performing the same procedure(s) which previously failed and generated the error dialog (pop-up).
"Today's the best day of my life...and NOW you're part of it!"
2answers
Loading problem
try to run again the system restore cd, what OS you are using? is it old or new acer laptop?
if you have new laptop with Vista OS it should be ok.
if you have new laptop design for vista but rather installed XP maybe you will encounter difficulties loading drivers if you dont have xp driver cd (acer provided)
if you have old laptop with XP OS it should be ok.
if you have old laptop w/ lower memory and trying to install Vista it will not work or you will incounter difficulties
Top 321studios Computers & Internet Experts
Vinho Xie
Vinho Xie
August Brown
August Brown
Are you a 321studios Computer and Internet Expert? Answer questions, earn points and help others
