Question about Fender Passport Deluxe 500watt Sound System with Deluxe Speaker Array
MY Fender Passport P250 went into protect mode. I changed the FUSE at the power supply with a new fuse. Still it is in Protect mode. How to fix this
  • Fender Master
  • 5,603 Answers
This needs to go to the repair shop. The protect mode is turned on when either the power supply has a problem or one or both power amplifiers have a problem. These are often blown components.
These units are HARD to work on. To open you have to first remove then front panel before you can remove the back panel that has the power supply and power amps/heat sinks.
Compare repairs of these units to working under an automobile dashboard!
Hint: On startup, use a series 150 wat lamp to limit current while repairing. SInce these use a switching supply operating off the input line, use an isolation transformer for personal safety.
Posted on Oct 04, 2009
Mi fender passport se puso en modo protect yacambie los transistores 5242 y sigue sin funcionar.
Posted on Sep 02, 2012
6ya staff
SOURCE:
I think I may have blown the power supply on my Fender Passport 500 (Part No. 069-1001) when I inadvertently switched the power selector from 240v to 110v. I still had the power cord plugged in and the...
BAD NEG. 15V REGULATOR AND RELATED CAPS IN POWER SUPPLY.CAUSES UNIT TO GO INTO PROTECT. main supply caps and power transformer is gone. possible you'll have to trash. good success, meder's tv service
Sep 15, 2012 | Fender Passport Deluxe 500watt Sound...
Protection light came on then went of now i get nothing when i flip the switch to on.
Likely an overload failure caused the protect light to come on, and then the fuse blew so all power is off... Do NOT replace the fuse as you will LIKELY do additional damage to components. Take unit in for repair immediately.
Note: These units are really hard to work on due to the way they are packaged.
Nov 23, 2010 | Fender Passport Deluxe 500watt Sound...
The protect light is the only light that comes on
Either one of the amps or the power supply has blown. The protect light means the power supply has been shut down due to overcurrent. Take unit in for repair. These are hard to work on due to packaging.
Oct 10, 2010 | Fender Passport Deluxe 500watt Sound...
We have a Fender P-250 PA system. We get the protect light on when we turn on the system rather than the green power light. We can not get it to operate. Please advise... Gary
Likely there is either a failure in one of the power amps or the power supply. The protect means excess current is being sensed.
You need to take in for repair... these are really hard to work on due to the packaging.
Sep 23, 2010 | Fender Pd250 Passport Deluxe 250watt...
Amp goes into protect mode as soon as switch is turned on. Pasport 250
There is a problem with the internal amp itself. These are extremely difficult to access. Contact Fender for a local authorized service center.
Dan
Mar 11, 2010 | Fender Passport Deluxe 500watt Sound...
Protect light comes on when power on
This indicates either one or more of the amps have a failure OR the power supply is being overloaded which is usually also caused by failure in the amplifier.
Occasionally a power supply failure causes this problem as well.
Due to the way these are packaged, they are a real pain to work on for repairing.
Feb 19, 2010 | Fender Passport Deluxe 500watt Sound...
My Fender Passport stays in protect mode.
I have one that has done the same. It is the next smaller size. The power supply fried a toroidal inductor in mine. Frankly, these things are a major pain to work on. You have to usually remove the front panel before you can remove the back power supply and power amp section.
If you have warranty coverage USE IT !!!
The protect feature in mine monitors the power supply load and shuts down the supply if it senses overload. They are hard to work on as you have to bypass the protect to troubleshoot and get to the root cause.
Use the old light bulb in series trick to limit the current.
Sep 23, 2009 | Fender Passport Deluxe 500watt Sound...
Fender passport goes in to protect
I had a problem like this that was caused by a short between the two windings of the toroid in the power supply.
The solder blob is probably supposed to be there as there are numerous common ground points.
This unit is miserable to work on....
Sep 08, 2009 | Fender Passport Deluxe 500watt Sound...
The 'protect light' comes on Fender PD150 Portable Sound System
The protect circuit is activated by a current sensing transformer in the *input* of the power supply. If any of the subassemblies of the unit (or all of them in combination) draw excess current then the protect light will illuminate and the power supply shut down to prevent any damage to the system.
The circuitry in the power supply is fairly robust as well as fuse protected so it is unlikely that the power supply itself has failed. More than likely one of your output power transistors has been shorted and it is easy to check this yourself if you are interested in doing so.
Furthermore if you follow a few *simple* precautions you can do this safely and confidently.
Post again on this thread if you are interested and I will spew the details.
-BK
Nov 28, 2008 | Fender Passport Deluxe 500watt Sound...
Fender Passport Deluxe 500watt Sound System with Deluxe Speaker Array Logo
3,949 people viewed this question
Top Fender Music Experts
Michial Gueffroy
rjivaro
Larry Stiles
Larry Stiles
Are you a Fender Music Expert? Answer questions, earn points and help others
