Tryed to change the memory then this happened and now i cant do anything
Hi, Daniell.
Remove all the memory and put your old memory back, again. See if it boots OK.
The new memory is probably bad, not inserted correctly or is not compatible with your old memory. Be certain that the speed is the same and is otherwise compatible. Check with your supplier.
Hope this helps.
Turn off power, take off the memory, clean the ram socket with clean dry brush, and clean the ram also.
You have a memory error...MABYE:
Look for the motherboard online and see who's bios it has, and its error codes.
Remove all memory...
Now, you dont know if its the slots or the memory, take ONE stick of memory, and place it in the first slot, start er up. then take that same stick, and place it in the second slot? Same result? Then take a diffrent memory stick and place it on the second slot.
