Question about Maytag Atlantis MAV6000 Top Load Washer
My Maytag Atlantis won't drain what is the problem
    New Friend:
Maytag atlantis washer mav35 when its in the Permanent Press Delicate mode the water does not spin out at the end of cycle. To release the water i have to spin the dial to spin in the Regular mode. Can you guide me to what the problem might be.
Posted on Nov 15, 2009
    President:
  • 1,304 Answers
Somethinmg is in the pump
Posted on Oct 05, 2009
5 Suggested Answers
6ya staff
SOURCE:
aquatom
Thomas Rutkowski
  • 108 Answers
SOURCE: Maytag atlantis mavt834aww stopped in mid cycle
Try unplugging it wait a minute and replug it in. This will sometimes reset the main board.
Posted on Sep 25, 2011
Lumpy816
Toby Norton
  • 246 Answers
SOURCE: Maytag Atlantis washer will not drain and spin unless you lift the lid
The cheaper thing to check first is is your lid bent? The lid switch is in the center of the lid. If it "droops" or has been bent, it shaft on the back of the lid cant hit the switch. Open the lid and apply pressure in the bottom, center of the lid. This usually corrects the problem without replacing the switch.
Posted on Jun 16, 2008
James Chandler
  • 686 Answers
SOURCE: I have a Maytag Atlantis Washer. At first it
post model number please
Posted on Apr 06, 2009
erica graber
  • 530 Answers
SOURCE: washer drains during fill
the drain hose is too far in your wall creating a syphone make sure that it is only 6 inches in your wall. this is the only thing that can make that happen.
Posted on Oct 18, 2009
Maytag atlantis washer water won't stop filling with water even when power is off.
water fill valve have a particle of trash or deposit from water.replace water valve and problem solved.
Jan 31, 2013 | Maytag Atlantis MAV6000 Top Load Washer
Maytag atlantis mavt834aww stopped in mid cycle and now won't do anything.
Sep 25, 2011 | Maytag Atlantis MAV6000 Top Load Washer
Maytag atlantis washer not draining
you say it does not drain...do you hear a humming? or is it dead? if it's dead you probably have a problem with your lid switch
Jun 01, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Maytag atlantis washer mav6300aww drains water but does not spin
my maytag washer model #MAV6300AWW will not spin out during cycle but can turn it back to spin and will spin out
May 30, 2010 | Maytag Atlantis MAV6000 Top Load Washer
How do I adjust the pump belt on Maytag washer ?
Depends on model.
For top load units with two belts under botton panel, tilt empty washer against a wall to allow access to belts and loosen the 3 pump mounting screws. See page: http://www.applianceaid.com/maywash_belt.html
Jan 07, 2010 | Maytag Atlantis MAV5000
Washer drains during fill sometimes. Maytag model-Atlantis - mavt734ewn
Oct 18, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV6200AWW Washer Problem?
I HAVE AN ATLANTIS MAYTAG WASHER . I HAD THE SAME PROBLEM AND I SOLVED AS FOLOLWS. REMOVED THE MOTOR, I APPLIED GENERAL PURPOSE GREASE ON BOTH SIDES OF THE SLIDING MOTOR SURFACE PLATE (MOTOR BASE) . THE GRASE HELPS THE MOTOR TO SLIDE BECAUSE AS YOU KNOW THE MOTOR DOES NOT HAVE ANY ADJUSTMENT. TRY IT PLEASE . GOOD LUCK
Feb 20, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
962 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
