When I press the power bottom the timer/standby light(red) blinks continuosly for about 30 seconds, but the set does not come on. Please adivse.
I'm having the same problem. My stand-by light blinks 3 times though. The tv clicks as if it is going to turn on, but it never does. Is there a simple solution to this problem?
+5 line is overloaded (AZ, BY, MZ boards) +5 line is shorted (AZ, BY, MZ boards)
IC504 is faulty (AZ Board)
This model has a common issue with failing DZ Board causing this fault indication. It is not a straight- forward swap, some wires will have to terminated onto to the board, the board itself costs around $170 to $200...
If taking to a serviceman try and get one familiar with Sony and aware of this problem, they should be able to quote for this repair...
I have Sony 29LS60 TV red standby light 4 times blinking and always repeats. There is no picture or sound.
Same problem
Timer/standby light blinks but no picture or sound when power button is pressed - Sony FD Trinitron KD-34xs955.
The Standby/timer button blinks but the tv wont turn on
Timer/Standby light blinks but no picture or sound when power button is pressed.
timer/standby light blinks 6 times then 4 times after that. no picture or sound.
ghbgch gfhfgh dfh
I have the same problem with my Sony Wega the standby/timer light blinks 6 times and pauses, then starts blinking 4 times. I have no pictrure or sound.
Walt
Min blinks fur times then pauses..no picture or sound..I have unpluged for 5 min then plugedback in..still doesnt work
Timer stand by lights continuously, have no picture, but I have sound. Dvr box connected, all shows recorded. I turned the tv on and off, checked for loose wiring, and unplugged and replugged, but still same problem.
My set started this problem today. The red standby light flashes 6 times pauses then repeats. There is no picture or sound. I have disconnected power, but this has not helped.
I just joined the rest of you with the same problem. My TV is only 5 years old, KV-32FS100. Stand by timer blinks continuously. My VCR came on and is recording, but no tv picture or sound. Guess I will try unplugging it for a while.
sony kv-32s40 my tv will not come on.but standby lights blinks. what can i do.
Stand by timer blinks...tv does not work
I have the same problem the timer/standy bu light blinks but no picture or sound when power button is pressed. Please advise what I should do
yes 3 blinks then shuts off.my set is 3yrs old warranty is up. i paid a lot of extra money thinking i would get a trouble free tv. do you thing sony will help because it's seems a common problem??
Same problem with our Trinitron. Worked great until the moment it happened. TV was turned off after working fine. Trying to turn back on an hour later, we had a black screen, good audio and a blinking stand-by/timer light. Any advise would be helpful. Thanks.
I have the same problem. The standby/timer button continuously blinks. I am thoroughly annoyed. What can I do to fix it?
same problem after 6 years. wouldn't turn on after gifting to a friend. really bad PR.
I turned my tv off for about 20 minutes and when i came back to turn it on, it flashed stand by/timer but no picture or audio. What do I do?
My Stand by timer light keeps on blinking. I have tried unplugging and rebooting but nothing works! PLZ HELP!
I have sound but no picture the light just blinks - what do I do
my rca d34w20 standby light blinks but wont turn on what do i need to do to fix this
When I turn on my TV the stand-by light blinks 3 times. The TV clicks as if it is trying to turn on, but it never comes on. Is there a simple solution to this?
When I turn on the TV my standby light blinks 3 times. It will click as if it is trying to turn on, but it never does. Is there a simple solution to this?
Exact same problem
My Sony KD-34XBR960N tried to turn on but unsuccessful with red led blinking.
how much to fix this problem? who can fix?
