Check the water discharge nozzles are not blocked.
You may need to clear the small discharge orifice with a strand of fine wire or similar tool.
If all water delivery tubes etc are clear, perhaps the water pump is defective.
Check it's water delivery capacity is ok.
You may have weak pump,or bad nozzoles,or clogged nozzles, also make sure their are no leaks in hoses going to nozzles. hope this help you.
Check pick up screen on pump for blockage...
