SOURCE: H500 won't pair with Blackberry Curve
It might already have been figured out but if you hold the answer button on the headset down until the light stays on steady, it is in pairing mode. You can then go to bluetooth setup on the Curve and it will find the headset.
SOURCE: Pairing Motorola H500 Wireless with Blackberry
Try the steps listed in the solution found here
http://www.blackberryforums.com/general-blackberry-discussion/18109-bb-7520-motorola-h500-pairing.html
Hope that helps
SOURCE: Cant Pair my Motorola H500 to my LG Rumor
turn bluetooth on your phone on. then on your bluetooth headset hold the power button for about 10 seconds or until you see the bluelight on steady. next on your phone in the bluetooth section klick ok on the search for device option, when you found the bluetooth with your phone it will ask if you want to use that device, klick yes, and it might ask you for a code, enter four zeros "0000" and that should connect automatic.
SOURCE: pairing Motorola D650 to Motorola S9 with ipod nano or touch
It does work with the itouch. Try turning off the ipod completely. Turn it on again, then plug in the D650 and then your S9. Enjoy!
