Televison & Video Logo
Posted on Dec 23, 2007
DTV remote code
I have a Panasonic PVQ-2510 VHS/TV combo that I'm looking for a working remote code for the DTV remote.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Dec 25, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1103
Points
KZXten,
Don't know if this will help but I have Comcast as my cable TV provider and am using a Motorola DCT-6200 STB and the remote Comcast provides with the STB. To get my Panasonic TV/VCR combo (PVQ-2510A) to work with the Comcast remote I had to do the following:
1) Do the remote code search in AUX mode (or VCR or DVD mode if your remote has that button instead) using the instructions for searching ing remote codes. I had to toggle back and forth between AUX and POWER on the remote until the TV turned off. I saved that code on the remote, but it only controlled the power on the TV, not the volume control.
2) Next I did the remote code search using the TV button on the remote and toggled between the TV button and the volume control until the volume +/- bar appeared on the screen. I saved that code too.
I use the AUX button to turn the TV on and off. Once the TV is on the volume control on the remote operates the TV volume normally. I still need to toggle between CABLE and AUX depending on which device I'm controlling, the cable Set Top Box (STB) or the TV. You may have to experiment some to get it to work correctly.
Here's a link to the remotes Comcast is providing in my area.
http://www.comcast.com/corporate/customers/customer_support/remotes.html
I am looking for the direct tv remote code for tv model PVQ-M2509 Panasonic Omnivision VHS como.
Hello
Four digit universal remote code for Panasonic TV-VCR combo are:-
0374 0381
Three digit universal remote code for Panasonic are:-
003/ 054/ 055/ 062/ 070/ 148/ 149/ 170/ 171
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
1helpful
Auto channel program
Universal remotes don't like combo units.If your original reomte worked before you lost it you are going to have to buy the original remote to solve your problem.
Does this tv have a digital tuner
According to an E-mail I received from Panasonic Support, it will need a digital box to work after June 09
2helpful
PVQ-2510 service menu
If you fix the vertical cirrcuit correctly, there is no need to go into service menu as your vertical should go back to normal. Re-check your work. I remember one cap on this set that gets overlooked all the time so you may want to check it. It is cap C413 - ceramic cap and sometimes it shorts causing a vertical shrinking as you described. Good luck.
2answers
PROGRAMING REMOTE TO TV
This is a comon problem, look up your code again, but notice combo, look at just the tv, now the vhs, try all of these codes
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Picture suddenly went dark
Hi, Apparently you have a possible component failure with your Panasonic PVQ-2510. This would involve the circuitry at the back/neck of the picture tube. Diagnosis would require familiarity with discreet components, use of a VOM, soldering and general component knowledge. In as much as it is possible that your red drive transistor (or an IC) would require replacement or resoldering, your best bet is to seek the services of a qualified professional. Should you venture to do a do-it-yourself, pls post back. Good luck and kind regards.
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
