Coffee Makers & Espresso Machines Logo
Posted on Oct 06, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Faema Due. Every time I press the right group buttons (any button) to extract, the left group also deliver water. The problem does not work is in reverse. I notice this start to happen as I get hot water at the end of the day. It seems the controller somehow try to synchronize the 2 groups! How to stop this from happening?
Ernest R
Level 3:
  • Master 1,618 Answers
  • Posted on Oct 07, 2009
Ernest R
Master
Level 3:
Answers
1618
Questions
0
Helped
730195
Points
3103
The brew valve on that side needs to be replaced, the expansion valve will also need to be checked/replaced.
1helpful
I have a Faema E91 3 group. I need to change it from 3 phase to single phase. any advise you can give
No, you will not have to change the elements, though the connexion cable will have to be approximately twice as thick. The three phases will, of course, deliver their power alternately, and the thinner neutral cable takes account of that. Do seek professional advice before connecting it to the mains supply.
I have a Faema E91 3 group and all the buttons click and work except two.
Try reprogramming buttons if that doesn't work, then the keypad is going out.
How to set the time on a Bedol Squirt clock
The right button in the frame of the clock face is chooses mode; it cycles through alarm, date and time, in that order. The left sets alarm, date or time.
1)To set the time:
Press the right button 6 times until the hour display flashes. (Make sure it is the time and not AL = Alarm)
Press the left button until you have the correct hour (note AM or PM)
Press the right button again until the minute display flashes.
Press left button until you have the correct minute.
Press the right button then the left button; the colon should flash.
The clock is set.
2)To set the alarm time:
Press the right button twice until the hour display flashes. (Make sure AL is displayed in top right hand corner)
3)To turn on the alarm:
Press the right button once
Press the left button once
There should be a symbol which says "AL ON" near the centre top of the time display.
Press the right button 3 times until the colon flashes
The alarm is on.
There is also a way to get a bell symbol displayed at the centre bottom. (I didn't test what it does)
4)To set date:
Press the right button 4 times until the month display flashes.
Press the left button until you have the correct month
Press the right button again until the day display flashes.
Press left button until you have the correct day.
4helpful
Faema due
It is possible that the solenoid on the group head is blocked, or the coil is damaged, or the metering jet on the top of the head is blocked. Since there is no click then I think the coil might be the problem. Disconnect the black electrical cover with screw in the middle, lift up and using an ohms meter check for resistance between left and right curved prongs. The flat one is the ground so ignore that one. If you have resistance, then remove the 14mm discharge chute, then the nut, washer and large flat washer and slide out the coil. DO NOT REMOVE THE SOLENOID FROM THE HEAD UNLESS YOU HAVE BREW VALVE GASKET TO REPLACE THE OLD ONES. TURN OFF THE WATER AT SUPPLY VALVE. MAKE SURE MACHINE IS COLD. Using a wrench remove the silver part of the solenoid body from the brass part connected to the head. Check the 2 holes in there and make sure they are clear, you can briefly turn on the water to see if it flows out of there careful it be a powerful stream. Reassemble and test group head.
Can you please tell me how to delete individual frames without deleting everything. I have had a bad experience and don't want to repeat it. I can't find my manual....Thanks
Video clip cutting (extracting)
Display the video clip from which you wish to extract a segment.
Display the NORMAL Mode
Playback Menu (page 37), select
"EDIT VIDEO, and press the
button.
Select CUT!! and press the SET
button.
The Cutting Screen appears.
Specify the start point of the extract.
Use the procedure below to specify the frame from which the video clip extract will start.
• Play the video clip until approximately the desired point, pause the video clip, then play the video clip one frame at a time, stopping at
start point of the extract. This will be the first frame of the extract.
• If the start point of the video clip is also the start point of the extract, proceed to step 5.
Play:
After pausing playback, press and hold the SET button to the right
about 2 seconds for forward playback, or to the left for reverse playback.
Pause:
During playback, press the SET button.
Accelerated playback:
During playback, toggle the SET button to the left or right to change the playback speed.
Single frame:
After pausing playback, toggle the SET button to the right to move forward one frame, or to the left to move back one frame.
5
Toggle the SET button up.
• The start point of the video clip
extract is set, and the screen
•Specify the end point of the
extract by following the same
procedure as in step 5.
a. Toggle the SET button down.
Each time the SET button
toggled down, the sections
delete and the sections to
save are reversed.
b. Specify the end point of the extract. The frame following
end point of the extract will
the start point of the latter portion to be joined.
6
Press the VIDEO CAMERA button.
A screen appears for you to select either to save the edited video clip as a new (separate) file, or to delete the original video clip and replace it with the edited video clip.
SAVE AS NEW:
The edited video clip will be saved as a new file. The original video clip remains unchanged.
OVERWRITE:
The original video clip will be deleted. Only the edited video clip will be saved.
REVIEW CLIP:
Play back the edited video clip before saving it.
7
Select the desired option, and press the SET button.
• Editing starts.
• When editing ends, you are returned to the NORMAL Mode Playback
Menu.
I think this is what you are after if this isn't what you need you can find the manual at
http://www.retrevo.com/support/Sanyo-VPC-CG9-Camcorders-manual/id/18378dj397/t/2/
Bought a used Faema Eurostar Combi. Don't have a
If it's the same as the used one I just picked up, there is a dial position for coffee, with a little cup on it. The dial position for steam is the one that cares about the positoin of the steam/hot water button.
The coffee position will never use steam and you don't need worry about the position of the steam button if you're not frothing milk.
I have a faema due automatic single group. Works fine except I cannot program shots. I hold down the "stop" button as per the manual, but there is no "beep" initiating the programming mode. What is wrong?
Hold down button for 8 to 10 seconds. If that is not working then you might have the older model in which you have to hold down the stop plus the button that you are programming until you get the desired volume then release button and stop button.
6helpful
I Have descaled my Saeco Odea Go but still it doesnt brew coffee
That is serious, that means the grinder is jammed or not working. To check the components of the machine follow these instructions.
Press and hold the steam button and turn on the machine, when you see the lights going around in anticlockwise direction, release the button. Turn the coffee dial to the left and press the steam button, the grinder should turn. Dial on the right and pressing coffee ****. water pump runs. Press steam ****. brew group go up, dial 1/4 to left B/Group down.
If grinder not turning the motor is bad. Hope it will help to find out.
1helpful
Hi need to know the program system for a faema smart 2 group
Press the stop button and the button you are programing together, then keep them held down until you get your level then release.
Top Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sulejman Sulejmani
Sulejman Sulejmani
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
