Question about Amana 16.7 cu. ft. / 473 liter Upright Freezer Deepfreeze AFU1767AW
Amana upright freezer leaks water on floor instead of in drip pan under it.
    President:
  • 1,304 Answers
Check the flor of the freezer if it is caked with ice your defrost drain is clogged
if not
take off the back panal
under the machine follow the drain tube
to the drain pan clean out your duck bill and make sure the tube is in the pan
Posted on Oct 06, 2009
Does the upright freezer model# 29701000D have a drip pan?
if it is a manual defrost freezer it will not have a drain pan. if it is a frost free freezer then it will have a drain pan
Jul 27, 2014 | Freezers
Water on floor
Check your drain hose that leads to evaporator pan. The hose should be in the pan. If it is in pan, then check to see if all door gaskets are tight and no leaks or gaps. This likely is the problem assuming you don't have a leak in the water line leading to ice maker. Try these things first and then we wll move to the next possible solutions.
Mar 14, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
My frost free freezer has had a small puddle of water under the front right corner several times now. I unplugged it and let it defrost completely thinking that would stop the problem but it hasn't. Can...
There is a chance the water is coming from the drip tray and or the drain hose to the tray.
when the unit goes into a defrost cycle it is leaking from one of those places check and make sure the hose is in the drip pan correctly and that the pan is also mounted properly and level.
If there is is a lot of water in the pan you may need to check the door seals on you unit and make sure they are sealing properly.
If there is an air leak then the unit could have excessive ice build up and also be defrosting more than usual amounts of water.
Jan 02, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Ice keeps forming on the bottom of the freezer - like a leak on the back side flows into the bottom toward the door.
When a refrigerator leaks water like yours, it is common for the problem to be nothing more than a clogged defrost drain. When the unit defrosts itself, the frost melt water drips into a pan underneath the evaporator in the freezer, and goes through a tube from there to the bottom outside of the unit. Since the water cant go down this drain, it backs up on the freezer floor, then eventually the kitchen floor.
Oct 06, 2010 | Amana 15.0 cu. ft. / 425 liter Upright...
Kenmore leaking oil
Hi!!
You have a Refrigerant Gas (Freon) leak. Oil travels with the Refrigerant Gas thru the system, that's why you see the oil on the drip pans, if you look closely you should be able to know where is coming from.
For what you are telling me, it seems that the leak is of considerable size, I recommend to ASAP take freezer to a Kenmore authorized service station for a repair estimate, then you can decide to fix it or get a new one. If you call a repair tech, he will charge for the house call regardles.
Good Luck
Don't forget to rate this post.
Jun 04, 2010 | Woods Upright Freezer V1613RW3
Our upright frigidaire freezer leaks water......not all the time...just every now and then
turn off power to frig or unplug and let it defrost, if water drips inside and no water drips in the pan on top of the compressor after defrost then the drain line that goes to the pan is clogged. also sometimes the pan itself develops a leak, but that will be self evident. If this resolves problem for a period of time and problem returns then probably defrost timer
Mar 09, 2010 | Frigidaire Freezers
Water leaks onto floor once a week or so from under freezer
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Nov 21, 2009 | Frigidaire 12 cu. ft. / 340 liter Upright...
Our upright freezer drips water on the floor. We believe the seal is bad since ice also forms inside at the top of the door. Is the seal replaceable or should we buy a new unit?
Self-defrosting refrigerators/freezers dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates.
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator/freezer compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Aug 16, 2009 | Freezers
Kenmore freezer peeing on my floor
  • if the door was not closed correctly for a while then a lot of condensation will be accumulated on the freezer coils.
  • then when going into defrost it melts this ice/frost and overflows the pan or container under the machine which relies on evaporation to dispel  of the water.
  • empty the pan under the refrigerator if you can, then give it another day, it will get back to normal.
if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Jul 12, 2008 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Amana 16.7 cu. ft. / 473 liter Upright Freezer Deepfreeze AFU1767AW Logo
565 people viewed this question
Top Amana Freezers Experts
John Tripp
John Tripp
Dennis Boxerman
Gil Shultz
Are you an Amana Freezer Expert? Answer questions, earn points and help others
