awm 6100 front loader door open light is flashing can't do anything, can't open doorawm 6100 front loader door open light is flashing can't do anything, can't open door
You can't post conmments that contain an email address.
Sounds like the front door switch has come out of place, or the actuator is out of place. If you can take the front cover off to get to this switch, you should be able to get it back into place pretty easily. Hope this helps, chad
It will be one of 2 things, a faulty inlet solenoid or an electronic controller issue, If you have a multimeter you can test the voltage supplied to the inlet solenoid and if there is voltage being supplied the valve is faulty, if there is no voltage then it is the electronics.
This is either a problem with the door lock itself or most probably a motor failiure as the door open light also indicates some kind of motor problem. If your appliance is 4/5 years and above then you will most likely need to change the set of carbon brushes on the motor and this will solve your problem
this door open light has nothing to do with the motor brushes its the door switch/s there are two of them try pushing your knee on the door if it starts working again change the switches and the brushes go into the motor?
I think it may have try and get your local engineer out to have a quick look tell your thinking of buying new and what price can he supply 4. and you like a free estimate .
