SOURCE: just black screen
Hi i have the same problem i think it is the power board you can buy these on ebay for about £200 i havent botherd as yet as i might just buy another tv as ive had no end of trouble with it dont think i would ever buy a hyundai tv again!!
SOURCE: Have a Sanyo Plasma TV
Yep. The power supply in Sanyo Plasmas are generally prone to failures. It could be a failure in the panel not priming, but I doubt it. Turn the lights off in the room, then try to turn it on. If you see the screen faintly flash, the panel is priming, but it is not coming on. If the screen is lit, but is still "black," then it is a control or digital board. If it is totally black with no light at all, then it doesn't entirely rule out the first two, but makes a power supply failure more likely.
They usually have a lot of heat damage to them. If you have tried unplugging it for 15 minutes, then plugging it back in and it still doesn't work, the it is most likely a secondary in the power supply.
I hope this helps you...
