Question about Sony KP-51HW40 51" Rear Projection Television
Sony rear projection whites appear green
My 66 inch sony rear projection is showing a green cast on whites..what is the common problem and how can I fix it.
    President:
  • 4,402 Answers
Http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Posted on Jan 16, 2008
6ya staff
SOURCE:
The color on our Sony KP-57XBR10 57 in. Rear Projection Television has become fractured. All images show in overlapping threes - one reddish, one greenish and one white. Can this be fixed, or should we...
Yes this set can be Fixed it is a common repair. You need to replace Both of your convergence ICs
They are Big Black ICs and will have Part Number on them example STK 392-110
Mats Electronics has ICs 1-800-628-1118
You will also need to check the pico Fuses that are in Front and back of ICs they look like resistors but will be Yellow or Green 5amps -7amp pico fuses make sure they are OK.
Jun 23, 2011 | Sony KP-57XBR10 57" Rear Projection...
The tv picture looks like should be wachting it whith 3d glasse
This is a very common failure on Projection TV sets. Its called a convergence failure. Here are some common symptoms.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
The other common problem is cloudy lens fluid. After many years the coolant in the blue and green lens will become cloudy and cause the screen to look dull, red/orange, bright white, etc. You may even see halos around objects on the screen.
You can see some example photos and find a solution here on Fixya.
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 15, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
I have a Sony 47 inch rear projection tv that is about nine years old When the set is turned on it has a good color picture but after a few minutes it tuns to a complete green sceen. Can you tell me what...
The green CRT may be intermittently bad or the focus screen block. Certain sony's are common to have bad CRT's. When the screen goes green does the set shut off?
Sep 20, 2009 | Televison & Video
50inch toshiba color problem
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 03, 2009 | Toshiba 50A62 50" Rear Projection...
Rear projection convergence issues
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 24, 2009 | Sony KP-53V80 53" Rear Projection...
Anything that is suppose to be white is green.
Check all of your connections, if they check out then the most likely cause would be a failure of the Optical Block.
Apr 22, 2009 | Sony Grand WEGA KDF-70XBR950 70" Rear...
Sony TV Screen
Is you model listed below?
Sony wega blue dot or star pattern on screen
http://esupport.sony.com/perl/news-item.pl?news_id=206&mdl=KDF42WE655
Models: KDF-42WE655, KDF-50WE655, KDF-55WF655, KDF-60WF655, KDF-55XS955, KDF-60XS955, KF-42WE620, and KF-50WE620
Jan 15, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Sony Kp-65wv700 Too much red -- white looks redish
fix the red:
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Nov 01, 2007 | Sony KP-65WV700 65" Rear Projection HDTV
Sony KP-51HW40 51" Rear Projection Television Logo
83 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
