I deleted programmes on my computor by mistake.the above was one. Although i tried to upload from the lexmark disc again the computor wont have it. Originally it was simple,up came my Lexmark imaging studio for downloading documents and photos easy.
Now all that comes up on screen is the Wizard and after a few ninutes it says it is installed . BUT IT AINT. im at a loss to know what to do i CANNOT correct it.
Im 66 and a bit computor illiteate im affraid. All plugs and usb ports are fine,
Gordonio
I had no problems with uploading my Lexmark X2500 All in Printer and it worked fine for a few weeks. But now it will only print if i try to use the Imaging Studio I get a pop-up that tells me that a Printing Application Error has Occured and i must close Windows (i'm 60 this is my first computer i've had it 3months no training) Mr M R J
Go to your control panel (found via start and then settings) and then go to add/remove programs make sure everything to do with your lexmark is gone. If not then remove it via this area. Then go to Start/settings and then printers make sure your lexmark is not in there either. If it is remove it from there. Start your install again after a reset of the computer and you should be in business.
