Samsung DLP HL-P5663W 56" TV Logo
Posted on Dec 24, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Samsung HL-R6167W DLP color problem/buzzing noise
My set suddenly started to buzz horribly loud (coming from back of unit) and the colors changed to a mostly purple hue? Any ideas?....is it possibly my color wheel gone bad?
  • 3 more comments
  • Anonymous Jan 01, 2008
    During start up, my HLR6167W has a loud noise similar to gears grinding in a car. Took the back cover off and it didn' sound like the fan at all. I've read a lot of other complaints about the color wheel going bad. Does anybody have a similar problem?
  • nelly57 Oct 24, 2008
    I'm having problems with noise from the back of the samsung tv. Need help, what can I do?
    Thanks
    Inelda
  • bswann Nov 16, 2008
    I have a similar problem. Is it cost effective to replace the wheel??
  • hemi8dad Dec 01, 2008
    have same tv, buzzing noise coming from rear. Tv does nthing now...
  • Anonymous Feb 24, 2009
    Same problem. Loud grinding noise and lots of purple on the screen.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 26, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2489
Points
My 3 yr old Samsung DLP has the same buzzing noise, had a tech out today and he said "color wheel". Thank goodness I purchased that expensive warranty, This is my 4th repair in 3 years.
Anonymous
Level 3:
President:
  • Master 4,402 Answers
  • Posted on Jan 16, 2008
Anonymous
Master
Level 3:
President:
Answers
4402
Questions
0
Helped
1709997
Points
8129
Http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
TV started making a buzzing noise at start up which gradually got worse ovre time until it would not shut off unless unplugged.
This tv unit have a colors wheel design into it.This tv problems,having loud squeling,buzzing noises or colors pictures are flashes black&white with the pictures.The tv colors wheel it is worn out and it is dying.The tv have a loud buzzing noises because the tv colors wheel it is worn out and warping out of it axis and it is spinning and hitting it steal frame box.The tv colors wheel sit way back of the tv behind many mechanical parts.Have no experience in mechanical works like take things aparts and putting it back again.Hire a tv tech. to change the colors wheel.
2helpful
I have the samsung DLP HL-6163W model. I've had this TV for 6 year, and have logged many hours on it. Tonight, the TV started making a buzzing noise in the back, and the colors got all screwed up. I...
This tv have a colors wheel design in it to this tv.The buzzing noises and the colors are all screwed up because the colors wheel is worn out and spinning off of is axis and rubbing it against the wall of it hall of the steal box frame that hold the colors wheel itself.Don't attemp change the colors wheel by ur self,if u have no mechanical skills.Bacause the colors wheel itself sit way back of the tv,have to take out many mechanicals parts,before can come to the colors wheel itself to replace it.Because u will regret it later if u putting the colors wheel itself in wrong.Hire a tv repair person to replace it.
1helpful
Loud hum and then an even louder grinding noise that sounds like something in a fan...Samsung hl r6167w
this is more than likely the color wheel is failing and needs replaced happens on dlp units frequently I would suggest replacing the color wheel should fix the problem
Buzzing sound on samsung
it sounds that u have a color wheel problem my friend
1helpful
My samsung dlp has a loud buzz/hum noise when it comes on and them remains though somewhat less loud
The buzz can be the color wheel or one of the cooling fans going bad. The only other thing that could cause a buzz would be the ballast going bad. Call a local repair shop to further diagnose the problem
2helpful
2answers
My tv is making a loud buzzing noise
Bearings in color wheel going bad and needs to be replaced. Call a local tv repair shop on pricing and availability of color wheel for your model and chassis
number.
1helpful
Samsung DLPTV bad picture and buzzing sound
You color wheel blew a bearing. You need to replace the color wheel.
4helpful
My 61" Samsung DLP has loud Buzzing sound - Everything else ok
There are only 2 moving parts on a dlp tv the color wheel and the fan. The color wheel needs to be replaced about every 4 to 5 years. Some start to make noise and others like mine blow up with a bang. Go to utube to get instructions on how to replace it only cost me for part $100 good luck
Cooling fan buzzing
Yes,don't do it yourself,and you need to have repair tech. asap,cause if the cooling fan is not working properly,that could trigger other parts in the tv to be malfunction.
Hurry,just it fix!
solutiondoct
Buzzing Noise
Set has a defective color wheel. This needs to be replaced and your tv will go back to normal.
josh
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
