JVC AV-56WP30 56" Rear Projection Television Logo
Anonymous Posted on Oct 08, 2009
AV-56WP30 Convergence Repair
I have finally found time to install the convergence repair kit for my JVC AV-56WP30 and I have noticed 2 resistors that might be bad, can you please tell me the resistance value for R842 and R858 so that I know which resistors to replace them with? Also, could those bad resistors be the problem and not the chips? I don't want to replace any more than I need to at this time..
Anonymous
Level 1:
Problem Solver:
  • Contributor 1 Answer
  • Posted on Oct 09, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
Questions
Helped
612
Points
I got the correct answer from another free service, I can't afford your paid service and listed below is the only answer that I received from you for free:
AV-56WP30 Convergence Repair - fxnlogo_s.png Technical Support, Instructions & Repair Service
Dear lmoore44052,
A new solution has been posted for your JVC AV-56WP30 56 in. Rear Projection Television problem on FixYa.com.
Click here to read the solution:
http://www.fixya.com/ThreadView.aspx?thid=3140051&prdid=186352
Regards,
The FixYa Team
Double faces with red 'halo' around people...after TV 'popped' and went off then back on.
Replace the convergence ICs and resistors. You can get the JVC repair kit called the AV48WP30 - AV65wp30 convergence repair kit from www.tvrepairworld.com which contains the ICs, Resistors, and the CD with repair instructions.
Display out of focus
convergence issue. The JVC repair kit called the AV48wp30 - AV65WP30 convergence repair kit is the correct kit for your model and symptom. Its available from www.tvrepairworld.com and the kit contains the parts and the CD with repair instructions.
The tv is blurry it seems the colors are not lining up.
Thats a common problem caused by failed convergence ICs. You can get the AV48WP30 -AV65WP30 convergence repair kit from www.tvrepairworld.com the kit contains the ICs, Resistors and the CD with step by step instructions for the repair.
Colors are off balance on screen
Ur convergence is dead.Must change convergence ICS all of it resistors.Know how to solders?Buy a convergence kit at Tv repair World.com,Tvrepairkits.com repair it ur self.Shop well cost u $300 dollars for parts and labors.
1helpful
I have jvc av-56wp30 all of a sudden the red in the picture is doubled. any ideas what that could be?
That sounds like a convergence failure. The AV48WP30 convergence repair kit from www.tvrepairworld.com should solve the issue. The kit contains the components and the CD with instructions.
2answers
JVC AV-56WP30 has red onlines in picture (maybe red bulb ?)
This is a 2002 model----if picture looks 3d it has a convergence problem---if you go into the customer menu with the original remote select convergence and see if it will adjust----IF the answer is no, let me know and I can tell you what is involved to repair this problem.
SD TECH
Color
you need to install a convergence repair kit which should take care of that issue. Heres a link to the repair kit for your model. The kit contains the parts and step by step instructions on how to do the repair.
http://servicemanuals.vstore.ca/product_info.php/pName/av48wp30-convergence-repair-kit/cName/convergence-repair-kits
Convergence is off on jvc av-56wp30
You will need to install a convergence repair kit which contains two Convergence ICs STK392-110 and then the associated resistors as usually a JVC will Need at least 1 or 2 of the resistors when the ICs fail. You can get the kit for your model at the following link which has the IC and all the resistors plus step by step detailed instructions on how to do the repair. This kit fits your model JVC
It powers on and has sound but cannot see the picture clearly. The picture on the TV is like in the middle of the screen and very small and blurred. 2005 56" Jvc I'Art Pro 1080i HDTV AV-56wp30
Your TV most likely has one of two possible problems.
Problem #1 - Failure in the convergence circuits. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed. Notice how dull the colors are and how white the screen looks. The screen may also look red, orange, dull, etc.
TV set after fluid change. Notice how bright the colors are now. Everthing looks crisp and sharp again.
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
2helpful
JVC AV-56WP74 Convergence part #'s
(2) STK392-110 Convergence Amp ICs
(3) 220 ohm 2watt metal film resistors
(3) 150 ohm 2watt metal film resistors
(2) 1.5 ohm 1watt metal resistors
(2) 2.2 ohm 1watt metal film resistors
(1) 1.8 ohm 1watt metal film resistor
(1) 3.3ohm 1watt metal film resistor
You can get the entire convergence repair kit which contains all the parts listed at the following link its called the AV48WP30 Convergence repair kit , but it applies to your model as well, and they include free installation instructions.
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
