My 40 inch Mitsubishi LCD TV, model LT-40134, just began showing multi-color vertical lines on the left half of the screen (approximately one third of the screen, overlaying the picture. At first, they went away after turning set off and on. As a few days have passed, the lines began staying longer and now they won't go away. Sometimes turning the TV on its swivel base was enough to cause the vertical colored lines to dissapear and for the underlying video content to reappear.
Any idea what is causing the problem and have you heard of any similar problems?
SOURCE: colored vertical lines on half the screen
yeah get a new tv, and not a mitsubishi, they all seem to have the same prob over time. the lines mean that your picture is on its way out
SOURCE: Mitsubishi 40" TV, LT-40134 Vertical lines on left side of screen
I've got the same TV with the same problem. Sometimes by moving it on the stand the lines will go away but it only sometimes temporarily fixes the problem. For a while it seemed like it needed to heat up to go away but that is not the case. It seems like there is a bad connection somewhere but i cant seem to find it. One day, one thing will fix it, then the next day it wont do the trick. It gets very irritating.
SOURCE: i have this mitsubishi lt-40134
You either have a malfunctioning LCD controller(T-Con) or a faulty LCD panel. The LCD controller is inexpensive and easy to replace where as the LCD panel costs nearly as much as a new tv. I would suggest that your replace the LCD controller and see if resolves the problem.
Sai.
