Microsoft Windows Vista Home Premium with Service Pack 1: Windows Logo
Posted on Oct 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Vista will not install on wd sata 640gig with vantech controller card 2 port pci. blue screen when vista boots .So installed w2000 and tryed to install from win2000 but ask for my controller card files but i then get mess. no entry pt. file wcstoui64 could not be located in msvcrt.dll /philip
Anika Tech
Level 1:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Contributor 24 Answers
  • Posted on Mar 10, 2019
Anika Tech
Contributor
Level 1:
Greenhorn:
Answers
24
Questions
0
Helped
4612
Points
68
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 273 Answers
  • Posted on Nov 07, 2009
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
273
Questions
13
Helped
54956
Points
806
Did you go into the bios to make sure the computer boots from the dvd drive and not the hard drive. Booting from dvd should install vista dvd files.
2helpful
(dual boot system)will not read a card reader in vista 32bit, but works fine in windows 7 64bit. Loaded drivers in Vista
Try driver download from her http://www.startech.com/Cards-Adapters/USB-3.0/Cards/2-Port-PCI-SuperSpeed-USB-3-Adapter-Card-with-SATA-Power~PCIUSB3S22
Although I dont understand your statement " will not read a card reader" since you state a problem with the Syba Infozone cable.
Is the problen your USB 3 port or the Syba cable.
2answers
MSI N1996 motherboard with 640gig sata drive / sata DVD ROM / NVIDEA Graphics card G7500 - wont boot up windows 7 even though i install new sata drive and try new installation it wont boot up! Pre...
hi there.
this is all the info i can find.plus try the link at the bottom might help you out some more.
If your computer blue screens when you turn it on, then loading in safe mode could help you get into your computer to sort out the problem. To boot safe mode in Windows 8: Hold Shift and press F8 upon startup to open Recovery Mode. Select See Advanced Repair Options, press Troubleshoot and select Advanced Options.
How to fix the blue screen of ***** - Cheeky Munkey
getting blue screen error Google Search
I have a compaq evo w8000 desktop and want to install a sata drive instead of the built in scsi drive. I can install windows xp (i've got the sata card drivers and pressed F6 etc, that all works fine)...
ok a very very old DT , desk top, ive done this vast times, back long long ago... 17 years old, you use this old of hardware why?
we dont use XP in uSA its VIRUS magnet. horred
and no updates, now, means will get worse each day forward in time. endless...
has built in, SCSI chip. l Ultra160 SCSI and Ultra ATA/100
that ATA means PATA port, not SATA back then.
my wild guess now is that someone put an a new SATA card in the PCI slot, (ive done so vast times)
The BIOS in your machine will never support that.
that means you can not boot to PCI SATA. for sure.b
but wait, the better SATA card works just like a new Adaptec
ultra160 card that if love.
the new SATA card has what is called a BIOS extension ROM on said card, and a new HOT key to access it.
some are CONTROL +A but each maker of said card ,does as he pleases, so READ THERE MANUAL.
you set it to boot o STAT port and it does if port 0 is bootable drive. SATA.
here ill take you now to newegg.com and show you hardware that works.
if you showed a photo of your CARD and # id have answered, 10x better. !!!!!
i cant shop for you, nor pick SATA 1 ,2 or 3 for you.
but here
https://www.newegg.com/Product/Product.aspx?Item=9SIAC0F5KW5808&cm_re=sata_card-_-9SIAC0F5KW5808-_-Product
the big trick here is making sure you relic MOBO
supports the current levels of PCI>
like above
32-bit / 66MHz PCI interface compliant to PCI Rev 2.3
(Backward-compatible with PCI 33
https://www.promise.com/media_bank/Download%20Bank/Datasheet/FT_TX2300_DS091406.pdf
Control +F (see page 11)
https://www.promise.com/media_bank/Download%20Bank/Manual/FastTrak_TX_Series_User_v3.2.pdf
warning, ive run in to big problems using very old relic
motor-boards that use the very old PCI signals and levels.
and will fail on some newers card
I warned you,
the above reads good. for that. (hope )
now my question why use such old hardware.
when goodwill has truck loads of 10year old pCs for $20
why, love of XEON?
id trash it.
find a use desktop with SATA ports, ALL DO now, or scrapped.
2helpful
2answers
How to install secind sata hard drive
It all depends on how many SATA ports are available on your motherboard.
Older motherboards (EIDE+SATA) usually only had one SATA port. In that case I'd advise purchasing an internal PCI SATA card (around US$ 30).
Modern motherboards (SATA + legacy EIDE) have two, four or even six SATA ports available, and you basically just have to screw the hard disk in an empty slot of the appropriate size (3.5"), and connect the cables. You may have to purchase both data and power SATA cables though. Then, format and install the drive (advice: use the one OS you use more often) from Control Panel > Administrative Tools > My Computer > Disk Management. And you're done.
Trying to run ms windows xp home install disk. I have the driver for the host controller, but when I try to repair or install new...it said it can not find disk drives. when booting up I can see the two...
Go through the prompts,then have your computers compatability wizard check first.Then look for the drivers properties.Then see if,after it installs the computer still doesn't read the disc then write or call microsoft.Or ask them online about this.
1helpful
HP a6412p added 2nd hard drive but wont work get blue screen
you should try switching the sata port you plug your new drive into. also, you should go into your BIOS setup f2 and save setting then exit.
2answers
Booting Problem
Hi there.
You will need to open your BIOS settings, and change your boot sequence/priority so that it includes PCI cards. Save and exit, and see if it then boots.
If you need anymore help, or need me to clarify anything, I'll be happy to help.
Tim
1helpful
5answers
How to uninstall Vista and load XP in Lenovo Y510 Ideapad
Several points:
1. Although you may prefer XP to Vista, it is probable that you are simply
more familiar with it. If you would give yourself some time to become
accustomed to Vista, you might find that you like it. I know I do.
2. You can't literally "uninstall" Vista, but if you want XP instead, you
simply do a clean installation of XP the normal way. That will format the
drive, removing whatever is on it.
3. Do you already have a copy of XP you want to install? Did it come with
your old computer? If so you need to be aware that OEM versions (such as
those that came preinstalled on computers) are permanently tied by their
license to the first computer they are installed on. If that's your
situation, your copy of XP is not available to be used on your new laptop.
4. Over and above the licensing issue in point 3, many OEM version of
Windows XP are BIOS-locked to the computer they came with, and you actually
won't be able to install it on a different one.
5. You should check with your vendor to be sure, but the warranty on your
new computer may be voided if you change operating systems.
6. Laptops often have special drivers they need for components within them.
Your new laptop undoubtedly came with all the drivers needed for Vista, but
it didn't come with the drivers needed for Windows XP. Finding and getting
the drivers you need may be a problem.
If I were in your shoes, I'd stick with Vista.
If you still want to uninstall:
The normal way to "uninstall" any operating system is to format
the hard drive and install a new OS of your choice.
After backing up any data you wish to transfer to the new OS
installation, simply boot from the WinXP Home installation CD. You'll
be offered the opportunity to delete, create, and format partitions as
part of the installation process. (You may need to re-arrange the order
of boot devices in the PC's BIOS to boot from the CD.)
HOW TO Install Windows XP
http://support.microsoft.com/default...B;en-us;316941
http://www.michaelstevenstech.com/cleanxpinstall.html
http://www.webtree.ca/windowsxp/clean_install.htm
Then the backed up data can be restored and applications re-installed.
You can even try a dual boot, where you have both Vista and XP on the same system. Click HERE for pictorial guide.
1helpful
Proxim Orinoco 8482-WD PCI Card, Driver installation locks Win-XP
Try the other way around,first install the card then boot the system up. When Windows finds the card and asks for the driver, insert your driver cd and choose install driver manually and point windows to your cd drive to force the use of the correct driver. It may be that windows is trying initially to install the generic driver.
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
