Whenever i turn on my tv its just a black screen with no audio or video. it has been doing this for 2 days, before i can just turn off the tv for a few minutes and turn it back on and everything will work but then within 5 minutes it goes back to the black screen. Now whenever i turn it on its just a black screen. Help?
If the power light stays on green, I would look tward a backlight issue. If you can see any image at all then the backlight controler or the backlights are bad. If there is nothing then if could be a power supply overheating or an inverter failure. More than likely as the unit heats up a failed solder connection is loosing contact causing the screen to go black.
Are you sure thats it? im pretty sure that everythings plugged correctly. some people have said that perhaps its fried?
ICheck the power supply connections make shure tht the plugs are seated correctly. The power supply isreplaceable as a complete uitand you have to return a repairable unit.
loumargo
Allied electronics
[email protected]
green power lite
no sound
black screen
worked until was turned off, when turned back on some time later , had the above problems tv is only two(2) months old what to do?
my tv nec m45 problem is when I switch on within 5 minutes went of and is black and wite in the screen thanks
