Supplied battery (BN-VF808) won't charge-up on my new camcorder. Green light blinks for 7 seconds, then turns off. Charging via supplied dock also no good. Camera works fine when plugged into powerpoint, though. Suggestions?
The only suggestion is that it's a faulty battery. You said the camcorder is new, take the battery back, it's under waranty, and get a new one.
Well, it is the problem of your camcorder battery ,since the external power supply can make your camcorder work well,you should check the interface between the battery and camcorder.another method, put a same model JVC camcorder battery in your camcorder, check the light,if it dosn't work, get a new one from the agent or camcorder batteries online store
Thanks mate. I was thinking along the same line.
Cheers!
