I m facing problem with my disk Event ID - 51 - An error was detected on device DeviceHarddisk0D during a paging operation. Source is disk. I m getting a lot of these messages in system events, Configuration is motherboard :ASUS P5GV-TMX manual has an entry showing storage/RAID -- 1 x UltraDMA 100/66/33 4 x Serial ATA hard disk info - one is SATA -I (40 Gb hitachi) supporting UDMA mode 5(ultra ATA/100) but active mode is UDMA mode 2(Ultra ATA/33) new SATA-II (250 GB WD)supporting UDMA mode 7(ultra ATA/133) but active mode is UDMA mode 7(Ultra ATA/512). Please tell wht to do?
hey I forgot to mention the thngs i already tried i tried disk check it says disk is good . no bad sectrs and all, disk is healthy i also tried just connecting one hard disk. in this case hitachi works in UDMA mode 5. without any problems. but western digital causes same problem. i tried formatting hard disk. DISK checks. reinstalling. none of this worked.hey I forgot to mention the thngs i already tried
DISK checks.
You can't post conmments that contain an email address.
It seems as serious disk drive error
to try fixing any errors that may be present on drive please run from command prompt [as admin] cd /D <faulty drive letter>
then chkdsk /r if asks to unmount <or scan after reboot if it is sys disk> say Yes <lonely Y also does the job>
this should fix the trouble, if not please send message
Testimonial: "How DO I sent u a message??? PLease help"
<span>When the computer/laptop cannot see a boot file/disk on either the hard disk or floppy drive it gives an error message </span>- <span>"No bootable device. Insert boot disk and press any key"</span><span><br /><br />First thing, check to see if the is a floppy disk inthe floppy drive, if so removes this disk.</span><br /><span>If there was no disk in the floppy drive then it maybe a hard disk problem.<br />Check the BIOS to see if the hard disk is detected, if not open the case and re-seat the data cable on the hard drive and also where it connects to the motherboard disk controller.<br />If it still gives this error message and the BIOS does not detect this hard drive, then the hard drive is probably faulty.<br /><br />A further check on the hard drive, remove the hard drive and connect it to an USB hard drive adapter and connect it to a working computer's USB port, if this computer does not detect it as an external storage device then the hard drive is faulty.<br /><br />To get the computer operating again, install a new hard drive in your computer and then install Windows on this hard drive plus the computer's device drivers and your programs.</span>
I too had lost some
of my docx file due to corruption so due to this reason i used Docx File
Repair. This software scans the corrupted file and repair corrupt
docx i.e. rebuilds a brand new one. Any user may get over internet for trial usage.
you could run the check disk utility click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive or go to control panel administrive tools computer management you can right click on the drive select properties tools check now?tick in both boxes to scan for and repair/recover any bad sectors and automaticall fix any corrupt files in xp hope this helps
First, extract all data that you have on the hard-drive, while you still can.
Seagate's web-site suggests that you first download and run Seagate's "Drive Fitness Tool", which exercises the disk-drive, and produces a "fitness" report. If it fails, then delete all your "private" files, and either take the drive back to the retail location where you bought it, or get an RMA (Return Materials Authorization) from Seagate, to get permission from Seagate to return the drive to them, for them to analyze the disk, and probably replace it.
DISK checks.
