Kodak EASYSHARE M1063 Digital Camera Logo
Posted on Oct 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
To reset day,month,year
New to me ,pressed day,then o.k. when not finished all the steps..now locked in at wrong month
Pania Lee
Level 3:
Genius:
  • Kodak Master 1,099 Answers
  • Posted on Oct 12, 2009
Pania Lee
Kodak Master
Level 3:
Genius:
Answers
1099
Questions
Helped
218828
Points
1986
Pls. go into menu, cam settings, set time, day and month, press OK and your new time and day should be set.
The Kodak Digital Imaging Support Centre can be contacted on any of the numbers below:
UK 0870 243 0270
International Toll line +44 (0) 131 458 6714
Anonymous
Level 3:
Brigadier General:
  • Master 11,967 Answers
  • Posted on Oct 09, 2009
Anonymous
Master
Level 3:
Brigadier General:
Answers
11967
Questions
0
Helped
2197911
Points
38521
Just go into the setup menu and try again.
2answers
I installed a new Honeywell RTH74/75 series thermostat and it has the incorrect day displayed.
Yes it will reset itself when you do that, it really should not be too hard to figure out the day.
How to set the time?
Timex Digital Watch
  • Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side
  • Press the "Date Advance" button on the upper right side. This will reset the seconds.
  • Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
  • Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
  • Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
  • When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
  • 0helpful
    Set time on wr50m watch
    Hi capttimpcb,
    To set the digital time and date on your Timex, please follow the steps below.
    1. Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side.
    2. Press the "Date Advance" button on the upper right side. This will reset the seconds.
    3. Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
    4. Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
    5. Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
    6. When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
    Hope it helps.
    Thank you for using FixYa.
    Resetting the time!
    Hi wizgrand576,
    Timex Digital Watch
    Hope it helps.
    Setting the time
    Hi frenchdscent,
    Hope it helps.
    4helpful
    How do i set a timex kids digital watch?
    Thank you for contacting Fixya.
  • Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side.
  • Hope this helps. Best regards.
    1440 date change
    Hi jhnmeserole,
    Timex Digital Watch
    Hope it helps.
    24helpful
    Need to reset date and time after changing the
    Here's the instructions on how to do that :
    Quick Instructions on Setting the Date/Time:
    1. To set the current date and time, press and hold down the SET/EDIT button for a few seconds. Release the SET/EDIT button when the Month (M) and Day (D) indicators start flashing.
      Note: The unit will revert back to normal display if no other key is pressed for 10 seconds.
    2. While the Month (M) and Day (D) indicators are flashing press the LOCK button to cycle through the 3 available date formats.
    3. Once you have chosen an appropriate date format press the SHIFT button to switch between each of the different DATE, MONTH, YEAR, HOUR, and MINUTE fields. The field that is currently active will start flashing. To change the field's value press the LOCK button. Each stroke of the LOCK button moves one value up.
      Note: If you go past the current year, you will need to press the LOCK button to cycle through the year 2189 and back up to the current year.
    4. Once you are finished setting the Date and Time press the Set/Edit button to return to the normal display. The Date/Time Stamper is now ready to print.
    The manual for this device can be found here :
    http://images.cableorganizer.com/dymo-label-printer/DateMark_Time-Manual.pdf
    2helpful
    3answers
    How reset time?
    Set the date and time
    You can set the date and time from the control panel. When a fax is transmitted, the
    current date and time are printed along with the fax header. The date and time format
    is based on the language and country/region setting.
    Note If your HP all-in-one loses power, you will need to reset the date and time.
    1 Press Setup.
    2 Press 4, and then press 1.
    This selects Basic Fax Setup and then selects Date and Time.
    3 Enter the month, day, and year by pressing the appropriate numbers on the
    keypad. Depending on your country/region setting, you might enter the date in a
    different order.
    The underline cursor is presented initially beneath the first digit; it automatically
    advances to the next digit when you press a button. The time prompt
    automatically appears after you enter the last digit of the date.
    4 Enter the hours and minutes.
    5 If your time is displayed in the 12-hour format, press 1 for AM, or 2 for PM.
    The new date and time settings appear on the control panel display.
    Regards...
    8helpful
    2answers
    Reset time
    Top Kodak Cameras Experts
    ZJ Limited
    ZJ Limited
    Grand Canyon Tech
    Grand Canyon Tech
    Are you a Kodak Camera Expert? Answer questions, earn points and help others
