Programming a sanyo tv with rcu403a remote and none of the codes work? do u have more codes ?
Hello Jeffro
Programming a device using the Code Lists:
1- Sanyo 017,021,039,056,057,058 (codes)
2- Press and "HOLD" CODE SEARCH.
3- Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
4- Enter the three digit code from the TV, VCR or Cable Box code lists. 5- Release CODE SEARCH.
6- With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists
Hope this helps you out.
Cheers Little Dish Fitter
Philips ................................. 003, 006, 008, 013, 015, 026, 046, 051,
..................................................................... 055, 064, 077, 089, 094
Philips Magnavox ....................................................................... 026
You can get a free downlod of the manual on the link below.
http://www.replacementremotes.com/RCA-Manuals/Download-FREE-RCU403-Manual-Codes-Operating-Manual.html
Good Luck
