That click might have originated in 2 places: either it was the main relay disconnecting or it was the sound of a capacitor popping. Both are very severe problems - they signal that the power source of your tv has just failed.
Fixing it is a job for someone with electronics experience, if you're not one then call a repairman.
3 times blink shows lamp cover is removed or not installed properly on TV. Please take out lamp inside TV and check, seems its broken as you heard loud pop. Thanks.
Most likely what happened is one of the capacitors went bad. When a capacitors goes bad it produces a popping sound. This could be an easy and cheap fix if you find the bad capacitor or capacitors. The bad capacitor will have a bulging top most likely on the power board but could be anywhere.
