Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Spin Cycle "Whines" and keeps spinning after cycle is complete
A couple days ago my washer started making a whining noise during the spin cycle. Today it appears to be spinning after the cycle should be completed.
  • Anonymous Mar 16, 2014
    whining noise when starting wash cycle
    Scholar:
  • 103 Answers
Need make & model # to correctly solve problem, it could be timer shorted or the drive motor has gone bad.
Posted on Oct 09, 2009
6ya staff
SOURCE:
Electrolux screaching noise on spin cycle
Hello friend, thank you for your inquiry!
Based off the information you have provided you are hearing a loud screeching noise during the spin cycle on your Electrolux washer. You will hear a certain amount of motor whine during the spin cycle this is a normal operation of your appliance. -Matt
Aug 23, 2014 | Electrolux EWFLS70JRR Energy Star Front...
Whining noise from kenmore elite washing machine during spin cycle
it is poss. the bearings are going. if you can spin the drum by hand and it makes the noise it is the rear bearing...
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
May 06, 2014 | Kenmore Washing Machines
I have a Whirlpool Ultimate Care II washing machine, model number: LSQ9110PW3 that stopped working properly two days ago. At first it seemed to not be able to go into the spin cycle. However, I just...
You have one of the best washers ever made... It is called a "Direct Drive" by us technicians. You probably need this part, but NEVER get rid of this machine as NOTHING out there is this good- not for anyprice. https://www.repairclinic.com/PartDetail/Whirlpool-Washing-Machine-Motor-Coupling/285753A/1195967?modelNumber=LSQ9110PW3&ss=a11b5d654521&mr=1
Apr 07, 2017 | Whirlpool Washing Machines
Very noisy and loud vibrations on spin cycle of Frigidaire FTF2140FS front load washing machine
Is it just during the spin cycle that it machine is noisy or the noise is less during the wash cycle? Also is the noise a thumping type of noise or is it more of a whining or steady noise? If is a whining noise, it probally means that water has seeped past the seal and corroded the bearing of the washer. The noise is the failing bearing.
Jun 30, 2010 | Frigidaire GLTF2940ES Front Load Washer
Only spin cycle
Check the lid switch, it only locks out the spin cycle.
eric
Jun 30, 2009 | Roper RAS8445KQ Top Load Washer
High pitched buzz/whine during wash cycle only, spin fine
1) Make sure valve is open all the way 2) some machines have a screen inside of the hose hook up which could be clogged. 3) last check to see if it is the hot or cold by switch your selector switch on your machine to hot then cold. If one of these positions eliminate the noise then the valve in the machine is bad.
May 16, 2009 | Maytag Atlantis MAV8000
Kenmore 80 series washer make high pitched whining noise
cold water screen in hose was half plugged causing it to either shut off the spin cylce due to lack of water or increase the spinning speed.
Hope this solves the problem.
Dec 10, 2008 | Kenmore 24032\24036 Top Load Washer
Rattling noise during spin cycle
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Nov 12, 2008 | Maytag MAH2400A Front Load Washer
Very noisy during spin cycle
You probably need new shocks for the washer as they break over time. They cost $37 each and you can replace them your self. If you don't fix these you may end up breaking the motor controller and while the part may be covered under the warranty the diagnostic and labor is not.
Nov 03, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing machine making whining noise during spin only
Yes, bearing, most definitely. It is a cheap part but difficult to replace.
Apr 11, 2008 | Washing Machines
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
377 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
