It's too expensive to change it on proper service or mall... you can purchase battery for amazon and change it at home, take a look here: Rayovac Batteries Lasts as Long Costs Less. I hope this helped. Cheers
I recomend to send it to michelle company go to their website and print the repair form all you pay is 22.50
i went to the mall and asked the other day they wanted to charge me 60 dollars
also these watches have a waterproof seal and once open they have to make sure they make it waterproof again and im sure they wont do this just everywhere . so i rather go for sure with mw directly im sending mine this week by the way
SOURCE: I just bought my wife a michele csx-36 watch. Its brand
that happened to me too...the watch repair man told me that I had the stop watch on. The stop watch should serve as a stop watch, not the second hand. The second time on your watch is the small dial at the bottom middle of the face. Once I turned off the stop watch feature, my battery life is fine...I have not had to change my battery in over 2 years now. HOpe this helps.
SOURCE: I need to replace a
Seals in water resistant timepieces go bad over time. This exposes the movement to moisture, dust, etc. which can damage your watch, costing expensive service or a new movement. If the watch is worn in the water often, the rule is to replace gaskets every 12 months. If it is occasionally worn in the water, they must be replaced every 18 to 24 months. The seals must be tested properly under the appropriate pressure for the rating of the watch by submerging the timepiece in a pressurized chamber. If your watchmaker is recommending this for a watch rated WR, water resistant, or 30M / 3 BAR don't bother. This should never be worn in the water. If it is for a higher rating (50M/100M+ 5BAR/10BAR+) and you wear it in the water, it may be worth the investment.
